Fluid extractor for trans or oil?
I haddah Google dat
Has anyone used one of these to extract transaxle oil?
http://www.harborfreight.com/cpi/cta...emnumber=66377
The PO of my 911 bodged the 915 drain plug and I can't remove it to change tranny oil. I've been removing the case cover to drain/change the oil, but the gasket is getting a little bit rough, and I need to find a way to pump the oil out through the fill plug hole.
Thanks, any suggestions are appreciated!
Team Owner
i have heard of this happening before . My buddy did it to his 944 , that was a 17mm socket. We fixed it by tack welding the head of a 17mm bolt into it and welding a nut on the other end of the bolt then it came out. Not sure if it was the tool we made or the application of heat but it can be done.
I haddah Google dat
I might have to wait until the tranny gets a full rebuild before I can get the drain plug out. I tried a nipple extractor, but the sides of the drain plug tore loose, and now there is nothing left to grab. I think I'll buy the vacuum fluid extractor if it comes with a 1/4" hose. I think that 90wt hypoid may need a large tube.
I haddah Google dat
Here's a pic of the drain plug. It's not a hex plug. The walls are very thin, and when it was rounded and probably overtightened, the thing split apart. When I tried the nipple extractor, the walls completely gave way.
I'm afraid that if I try a welder, I may damage the threads and not be able to get this replacement plug in there. I also think the plug must have been really tightened.
This is the 17mm allen key that I bought from Sears many years ago for the 911SC.
Take it to a good 911 mechanic who has probably freed many of these frozen plugs in all manner of disfiguration during his career. Then, do yourself a favor and buy the Pelican tool designed for this plug and you will never have another problem with it. The first time I tried to remove it I used the 17mm hex socket from my set and it wouldn't work. 2nd time I bought the Pelican tool and it came right out. Good luck.
I haddah Google dat
Thanks Chris. I looked on Pelican, and all I saw was this tool that looks like a 17mm allen wrench.
http://www.pelicanparts.com/cgi-bin/...r=PEL-DPR-1017
I realize the current plug in your tranny is beyond help but I'm talking about for future use with the new plug you will replace it with.
I haddah Google dat
oh, I get it. Thanks! BTW I don't buy tools from Harbor Freight. The one I pictured is a Sears Craftman, and their steel is much better than some. I have a hardened set from Lisle Tool, but theirs only goes up to 10mm. For 12mm, and 17mm I had to go buy a Sears tool.
RL Technical Advisor
I've had great luck is your situation by welding a cheap allen wrench to the plug, letting it cool, and then backing it out.
Install a new plug and you're good to go,.. .
