911 Forum 1964-1989
Mini success story with gratuitous pics
Old 05-16-2009, 02:36 PM
bodmin
bodmin's Avatar
Thanks Steely - your engine pictures are an inspiration. I'll get some pictures of my new car up when i get home (sometime after 29th May).
Old 05-16-2009, 07:52 PM
Steely
Steely's Avatar
bodmin - you're too kind. I may have sent that last response in haste, I wanted to explain that there is a set screw to aid in the adjustment of closing the switch went at idle. if you have a problem with idle and you suspect this is the cause, write back as there is a way to verify this easily by using a ohmmeter.
Old 05-17-2009, 01:27 AM
Ed Hughes
Ed Hughes's Avatar
The 944 crank sensors work too, and are 1/2 the price of the 911 parts.
Going this route means you don't have to install BMW junk on a Porsche.
Quick Reply: Mini success story with gratuitous pics
