Engine lid jammed on 83 911 SC
Brian Collins
If your cable is still operable, but the engine lid won't release, you can manually actuate the latch further than what the cable normally pulls it open. Meaning that if the "throw" of the latch is say 2", and your cable only pulls it open 1.5", you should be able to reach up there and extend it beyond it's normal throw to release your engine lid.
Once you do get it open, loosen the screw that holds your cable adjustment and tighten the cable up a bit.
Sounds like you have your engine lid a little out of alignment, (BTDT), and the mushroom shaped plunger, upside down and mounted to your decklid, is out of line just enough for the release mechanism to keep ahold of it.
Here is a "low tech" approach that may solve your problem. Get a second person to push down on the deck lid - while you pull the release cable by the handle.
This has worked for me when my deck lid does not want to open on my '80 SC.
good luck,
Maurice
the lesson I learned is to loosen that plunger for re-alignment whenever re-fitting the deck lid.
I did exactly what Maurice recommended - got someone to hold the cable yanked out, whilst I careful wiggled and depressed the deck lid up and down with my hands only the very extreme lower corner edges where the deck lid is strongest - anywhere to the centre and you're likely to buckle the skin and fracture the clear coat....... I've been there!
After it sprung, I just barely snugged the nuts up to allow me to move the plunger by hand. I then gently closed the lid without closing it all the way and the plunger had enough slack in it to re-align itself. I tightened the nuts a bit firmer and closed it all he way. Gave the cable a yank and up it sprang. Fixed.
The car has been sitting in the garage all winter (cold) and I popped the lid to look at something in the engine. Then, the lid would not close. It was then that I could see the latch acting a little stuck. I adjusted the post for some reason, thinking that would help, and it ended up closing but now won't open.
Is there any way to access the latch with the deck fully closed? How? Thanks.
