I need to re-hash an old topic- air conditioning in a Carrera.
I have an 88 911 Carrera that does not blow cold air. Last year I had the system re-charged with R134A (system was previously converted from R12). The improvement was minimal at best.
Griffiths offers the Kuehl kit with either 1 or 2 added condensers that mount in the driver's side wheel well. The condenser and fan is added in series to the OEM front and rear condensers. But, the price for the kit is far higher than my total installed price budget. I need to keep costs at a reasonable amount.
I am considering buying a current technology condenser and putting it in the same location using the same design concepts. My car has a newer compressor (Denso), but not the newest model rotary piston style. I have barrier hoses. I would add the needed hoses, install a narrow depth fan with associated hardware and needed wiring/relay. I also plan to replace the receiver/drier.
A few questions:
Will a new serpentine design condenser work with 1988 technology? I.e. are the fittings the same, are there any other potential issues to consider? The current condensers are tube and fin style. I would buy an American made condenser over one made in China.
What minimum dimension is best for the air relief area between the condenser and car body?
I know of an online company that offers OEM condenser replacements only. So I would have to select a condenser on a car with the desired size. For example, a 1997-2004 Boxster condenser is available at a slight premium to the other manufacturers. But they have a "block fitting" noted on the diagram in reference to the 2 refrigerant tubes. Does this mean that the 2 tubes fitting are grouped together in one small sized location? Or, does this mean something else? I am unable to observe the a/c condensers in my own '00 Boxster for comparison (they are installed behind a plastic shroud). The company is www.discountacparts.com
Thanks. Any help is appreciated.
A few questions:
I haddah Google dat
I don't think a non-911 specific condenser will work, unless you are planning to install one in the bellypan or in the rear wheel similar to the Kuehl. I have 134a, and I can get around 42F vent temps. I have the ProCooler and a stock ND compressor, as well as the stock condenser and evaporator.
I'm intrigued by the desert duty front condenser, but I have seen one blasted pretty good by a railroad crossing. The absolutely most exotic solution that I can think of is to somehow get a 964 condensor to work on a 911, but that is a huge project probably for years down the road when I'm bored and need something to do.
Do you want me to post a pic of the Boxter condenser parts diagram?
The issue I believe is airflow. The condensor should have air forced through it, so sometimes plates and seals are used around the outside edges to seal the condensor against the body.
Team Owner
.. not to mention the duct sizes to the cabin are just not big enough from what I have read to force enough cold air to make it continually effective. Even 42F at the vent is no good if you can't push enough volume of it into the cabin.
I put a 3 condensor Griffiths system in a 1976 930 and it was awesome, blowing 33 degrees at the vents. We replaced everything except for the interior vents and fan. Big $, but everything fit perfectly and Griffith's answered our few questions on the phone, no problem.
I considered piecing together a system on my own, but I could see that I was going to end up wasting a lot of time and money buying stuff that did not fit or work correctly, and that it was going to be tough getting reliable advice on what works with what. So I decided to do one stop shopping from someone who really knows what he is doing.
+1 on the Griffith's...seeing 29 degrees our of the vents in the mid-high 80s in humid Florida...I actually turn down the fan and temp selector to about 3/4 to get best performance.Kind of wierd riding in a cab inthe hot and humid and feeling cold and dry inside. Will keepyou posted when it gets into the hgih 90s here as far as performance.
I wrestled with the cost issue but finally decided to go all the way (4 condenser system)...
If I wanted to improve the cooling capability of our '88 Special Edition I would be adding a few 12 volt computer cooling fans to force air over the engine lid mounted condensor more consistently.
I haddah Google dat
29F vent temps means the evaporator/ EX valve has got to be around 19-20F? Either that, or there is no airflow from the cabin exchaging heat with it? You've got to have some serious condenser area to get that, and a very good evacuation to avoid freezing the exv.
Team Owner
. but if you came to Toronto you would have to put up with shoveling snow .. a team that has not won the stanley cup in over 40 years. being taxed every time you breathed , shoveling more snow and having Americans say " eh" to you all the time ..
Wow Clive you're sounding awfully anti-Canadian...lol
I haddah Google dat
This summer, I'll value my AC more than a mere 3 ounces of gold. We get 110+F degree heat. In July it goes from "Hot" to "Ludicrous Hot". In August it goes to Plaid.
I am happy with my kit from RetroAir. Everything stays in the stock location, just works a bit better. I get enough airflow. I have not tried it over 100 degrees though.
David
1988 Carrera
David
1988 Carrera
The key to improved performance in the 911 A/C system is more condenser capacity. Take a look at this rear fender kit offered by this company. You don't mention what your budget is but this kit is well priced at $599.
http://www.allzim.com/acatalog/911_A...it__87-89.html
