lloose fuel injectors, is this right?
While doing some misc. maintance on my 78 911sc i discovered that the injectors on the right side of the eng. are loose. At the place where they enter the head they can be turned and twisted in the mount ,is this normal?. the car seems to run fine and there are no fuel leaks . someone please let me know , i don't want to do any damage -Jerry
Technical Specialist
Lifetime Member
Lifetime Member
You're not going to do any damage, however a loose fuel injector o-ring could possibly let in a small amount of unmetered air, which is not welcome in a CIS system. After 23 years, assuming those are the original injectors and gaskets, the gaskets can get hard. On Monday I'll post an article on how to tune up your CIS fuel system, including how to replace the fuel injectors and fuel injector o-rings, in the event you want to tackle it.
Hello
But a drop rubber friendly oil into the gaps. Thee o rings will swell a bit and be thight again.
The O rings on the injectors can be easy replaced. The others on the thermal barriers need much work as the factory looked them with three pounches. If you dont grind them away your new O ring will get scrached during installation.
Those thing are replaced during an engine rebuild.
Grüsse
Grüsse
![Lightbulb](https://rennlist.com/forums/images/icons/icon3.gif)
Thank YOU ALL FOR THE INFO ,I CHANGED THE O-RINGS TODAY AND WOW , WHAT A DIFFERANCE . I MUST HAVE BEEN LEAKING A LOT OF AIR AND LEANING OUT THE ENGINE. you drive it for 23 years and the reduced performance sneaks up on you
