Help with '89 C2 Oil Cooler Removal
Greetings,
I'm removing my oil cooler (trying to!) on my '89 C2 to replace leaking seals. I've removed the right weeel, oil line from the tank to the cooler, the shroud along the valve cover, but can't seem to get to the top 2 nuts, in fact I can't even feel them. There is another shroud on the front of the cooler which but seems to be connected to 2 small lines up in there, so I'm unable to remove that. Are the nuts accessible from inside the engine compartment only?
Thanks! Greg
Thanks! Greg
I haddah Google dat
