911 Forum 1964-1989
Possible Track & Auto X Field Wheel Alignment Tool from HF & HD?
Old 04-11-2009 | 06:03 AM
  #31
DRACO A5OG's Avatar
DRACO A5OG
Hey you up late.
See you this Sunday and yes I will bring my tools to check your car
Old 04-11-2009 | 02:00 PM
  #32
Amber Gramps's Avatar
Amber Gramps
When are you two coming over to do Ron's bearings?
Now we can do secret ops, ghetto alignment, "don't tell" installs, and the ever popular steak out.
Old 04-11-2009 | 02:31 PM
  #33
DRACO A5OG's Avatar
DRACO A5OG
Hmmmmmm, I really need to do the bearing before the Auto X
Old 04-11-2009 | 02:50 PM
  #34
Amber Gramps
Um, ya...
Your throtle isn't sticking, is it?
Old 04-11-2009 | 02:55 PM
  #35
DRACO A5OG's Avatar
DRACO A5OG
Nope, Throttle is perfect. Why did you ask?
Old 04-11-2009 | 07:24 PM
  #36
Amber Gramps
Sorry, Ed doesn't like me bringing up past posts.
Something always happens....Let's call it murphy's law.
Old 04-13-2009 | 05:33 AM
  #37
rnln's Avatar
rnln
Doug had too much beer today
Old 04-21-2009 | 04:09 PM
  #38
rusnak's Avatar
rusnak
I haddah Google dat
I ordered Draco's alignment tool and I used it to get my front suspension back into the ballpark after changing the front bushings. The car now feels very agile, and very responsive to steering. It tracks straight and feels stable.
It is a very easy and very quick tool to use! I made another tool to check camber. I will feel good about driving it to the alignment shop, and they won't spend all sorts of time and (my) money when I have them check everything. When the suspension is miles and miles out of alignment, they always charge more.
I'm wondering how close I got it to spec. I'll find out in a few weeks, after I get to the rear suspension.
Old 04-21-2009 | 05:03 PM
  #39
theiceman's Avatar
theiceman
Team Owner
so which alignment tool did you get ? the toe one ? and whatdid you make to check camber ?
i would be very interested in how close you got.
Old 04-21-2009 | 05:14 PM
  #40
rusnak's Avatar
rusnak
I haddah Google dat
I'm still probably going to decrease the amount of toe before I do the rear suspension. I was thinking about it, and I think less toe will show more misalignment in the rear. In other words, if I go 1/32" toe in in the front, then the rear will have to be pretty damned straight for the car to track correctly.
Yes, I got the toe in/ toe out tool. It came in a fairly long box, so I was glad that it was delivered Fed Ex.
I'm going to use it on the rear suspension also. The tool I made to check camber is similar to the one Draco made, but it has rubber caps that press against the wheel. It's made out of aluminum angle, cut to about 17" long, and has multiple holes to be used on 16" and 15" wheels. I use it to do a visual check on toe before putting the wheels back on, to cut down the trial and error. It shows slight negative camber on both wheels currently.
Old 04-21-2009 | 09:41 PM
  #41
DRACO A5OG's Avatar
DRACO A5OG
Oh Glad it worked for you too. I am always looking to see if my alignment is going to keep and check the tires every week just to be certain.
Yes, please post your results at the alignment shop, it will be very interesting.
Old 04-22-2009 | 02:32 AM
  #42
rusnak's Avatar
rusnak
I haddah Google dat
you guys are free to laugh at my GET-toh wheel alignment precision instrument.
I had to try a modification to the dial. Halfway between those hash marks is 1/32". I'm going to screw or glue some lightweight balsa wood blocks on the measuring rod to elevate the tool even with the sidewall about an 1 1/2" off the ground, just below the wheel protector bead. This way I can standardize my measurements front to back. I think I can get pretty close with this tool.
Old 04-22-2009 | 03:03 AM
  #43
DRACO A5OG's Avatar
DRACO A5OG
Hey Brother We are laughen all the way to the Bank
Old 04-22-2009 | 03:54 AM
  #44
rusnak's Avatar
rusnak
I haddah Google dat
I dunno, I had a few good laughs when I first saw this thing. I'm going to look at the hobby store for some lightweight blocks of wood. I figure 1 1/2" of elevation will put the feeler just under 2 1/2" off the ground, which is perfect for both front and rear tires.
Old 04-22-2009 | 06:32 PM
  #45
DRACO A5OG's Avatar
DRACO A5OG
Yeah, for one person check the block would be a good idea. Please post your mod.
