911 Forum 1964-1989
Wheel and alignment set up question.
Old Mar 24, 2009 | 10:34 PM
Edward's Avatar
Edward
Addicted Specialist
Originally Posted by rnln
Ice,
hope you don't mind I ask the same question in here.
Hi Pete, Edward,
Can you suggest me the alignment spec. on my wide body (modified) 87, lowed, 17x9" front and 17x11.5" rear? Everything else is stock.
Thanks.
Hey bud,
I am no suspension guru , or guru of any type for that matter. But I have sorted out quite a few suspension and handling points via trial/error, and getting lots of advice from those who know these things.
That said, the initial posts with camber, caster, toe which I or Pete gave you should suit you fine for a street car. The difference (minor, at that) is that my recommendations are just a tad more aggressive from what Pete suggested. Come to think of it, with you running such wide rubber (especially out back), you may even want to go with -1 degree camber front and rear to dial out some understeer and make the car a bit more neutral. Hope that helps you some
Edward
Old Mar 25, 2009 | 10:17 AM
AJ88CAB's Avatar
AJ88CAB
Pete- thanks for the explination, having only ever driven my '88 cab (with the sport shocks) I won't try to offer an (un)informed addition. It does have a few suspension upgrades, and its obviously on the heavy side of the 911 family, but it feels good on the track and street to me, but I have nothing to compare it to. Your comment will give me something to pay attention to in my next drive/track event. It always make me think if this cab feels so good to me, how good must a solid coupe be...what am I misssing...can it really get better
Ice- sorry for the slight hi-jack
