How to retrofit air source for CIS-based 911's (long)
Technical Specialist
Lifetime Member
Lifetime Member
![Arrow](https://rennlist.com/forums/images/icons/icon2.gif)
Shortly after introducing CIS fuel injection in 1974/1975, Porsche changed how hot air was sent into the passenger cabin for heat and defrosting. Starting with the first 911 in 1965, the original air system consisted of a duct on either side of the fan housing routing air through the engine tin to the heat exchangers. The mid-70's system consisted of a fan mounted high on the left upper side of the engine bay, with 3 hoses, one for an air intake from the fan housing, and two hoses from the blower through the engine tin to each heat exchanger. Backdating the air system to the older style is easy to do, and Porsche sells the parts you'll need, or you can visit your favorite used parts dealer.
You'll need the following parts:
Left hot air duct, 930.106.321.02, list $148.20
4 plastic nuts, 999.591.592.40, list $.12 each
2 rubber plugs, 999.703.044.50, list $.77 each
Right hot air duct, 911.106.327.00, list $53.45
Right engine cover plate, 911.106.036.00, list $14.89
Right engine cover, 911.106.827.00, list $5.04
Right air duct support, 911.106.331.00, list $1.30
Hose (see below)
The left hand air duct has a bunch of holes in it to fit 911's and 930's, and the rubber plugs and plastic nuts cover those holes and allow other things to be screwed to the housing. I put a screw into each plastic nut to pretty well close off those holes. The left hot air duct is metal, and the right duct is plastic, while the engine cover and plate are metal. The right air duct support is to bolt the right air duct to the larger plastic cover over the engine. I didn't use it, as things seem tight enough without it, however, we'll see if over time I need to add the support.
Installation is straight forward, take the existing blower and hoses out of the engine. On my 81SC, the bracket that holds the motor also holds one of the vacuum pipes, so I took the whole bracket off, and cut off the portion which held the motor, leaving the portion that holds a support for the pipe. Put the left hot air duct in. On the right, unscrew the cover plate and remove it. Put in the engine cover plate, followed by the right air duct, followed by the engine cover. The right air duct has some grooves in it where the engine cover cinches it up fairly tight.
Hoses: I used 4 feet of 2 1/2" SCAT hose (silcone rubber-based, good to 450 degrees) from Aircraft Spruce and Specialty, cost $21. You'll cut two pieces for the left side (duct to engine tin, then below engine tin to heat exchanger) and one longer piece on the right (duct to heat exchanger). I've also seen an aluminum-based hose used, as well as other types and colors. The hose has to stand the heat in the engine compartment and more importantly the heat at the heat exchanger connection.
That completes the installation. Assuming your heater boxes are working, and the wires to the heater controls on the floor are also intact, you're done! Not much heat at idle, it picks up well as the revs increase. If you open a window just a crack, then that helps the heated air move into the compartment. And, especially if you've removed your air conditioning compressor, you can now see alot more of the engine!
Hose (see below)
Bill, do you have any pictures you can post? I'd love to the the visual improvement. It sounds like an easy Saturday afternoon project.
pbs911
78SC Targa
pbs911
78SC Targa
Lifetime Member
Lifetime Member
OK, here's the link to a picture. Note two blue arrows pointing to the hoses on each side of the fan. Picture is not of my 911, it's actually of a '65 911, but same look/affect after the retrofit.
![](http://boards.rennlist.com/upload/airarrow.jpg)
[ 06-06-2001: Message edited by: Bill Gregory ]
1 Post
It is a pleasure to read a fine presentation.My 77 911S has Webers in waiting.This is the first time I am giving any thought to the future of the heating system.It appears I have to remove the blower. -Is this true?- It is a street car, and at times I do turn on the self installed manual switch.It does supply plenty of heat on open highway in the blower "off" position,turning "ON" contributes little. In "light to light" street driving I do turn the blower "ON" if temp.is below 40 deg.The priority is Webers and E-cams,period.
Lifetime Member
Lifetime Member
One of the reasons to back-date the air system is to get rid of the blower and the 3 hoses, which adds considerably to cleaning up the engine compartment. In the older air system, air is sourced right from the fan assembly, so there is always air "on" to some degree. At idle, there's not alot of air "on" but when underway, there's alot more. Normally, with the heat levers down/off, the hot air is simply dumped out the heater box. The heater box is just inside each wheel well - you can see the hose running from the heat exchanger to the heater box.
Hello
The new heatersetup with freshairblower came as the normal traffic didn´t give much RPM for good heatet air suppley. Also the new setup made more constant heat witch helped the newthermostatic heating device mixing the correct temperature.
If you need more heat with the old setup then use the 3,2 frontblowers.
Just two things.
The right side duct has as descriped a cliped in nut and is screwed on at the fan shroud.
Under exact that screw is a little offset plate that will carry the rubberholder from the 4-6 ignitioncables. If you go to MFI or Carbs this will avoid that they will shuffle against the throttle cross shaft.
If you leave the screw away teh duct can vibrate under the airstream and shuffle trough the frontcarrierplates. ( You can see it sometimes on used parts.)
Porsche also changed later the cooling duct design slightly as the missing passenger side duct allowed to provide the air a bit different for equal cooling. The new duct came with the 3,0 SC. Mostly affectet will be the oilcooler. So keep an eye on that if you are at the limits anyhow.
Porsche uses a paper covered aluminium hose. Has benefits in heat and soundisolation. Also it will trap more dirt and oil then other hoses. Gates supplyed them several years ago too.
3,2 L with SSI can use that setup too but needs mor sheetmetall to be replaced.
Grüsse
Just two things.
Grüsse
