84-86 Fuel Pressure Regulator Guage
#46
"I don't know why it took me so long to remember this, but if your fuel pressure is off, more likely to be the fpr."
- rusnak -
A bad memory or a lack of even the minimum knowledge about fuel injection systems?
Like, isn't that the purpose of the fpr (fuel pressure regulator), ace?
"You can test is by installing a fuel line with a cutoff valve in the between the fuel fpr and the return line going back to the fuel tank. If the pressure is too low, then gradually cut off the valve while watching the gauge and running the fuel pump. The pressure should jump. If it does not, then your fuel pump could be bad."
- rusnak -
Wrong! Blocking the return line does NOT check the fuel pressure regulator,
only the max pressure of the fuel pump. Doing that can damage rubber fuel
lines and seals. Let's not mis-lead Rennlist members as is typically the case
over there on the "dark side".
By the way, maybe take a high school grammar class in addition to H.S. auto shop.
- rusnak -
- rusnak -
#47
"I have to leave my key in the "on" position for about 10 seconds prior to tapping the key to get my car to fire right up. I'm guessing the pressure is low."
- douglas bray -
"Another one" with misleading info for Rennlist members!
The fuel pump does NOT get power in the "run" position of the ignition switch
prior to "cranking". So turning the ignition switch to "run" and waiting has NO
effect on fuel pressure. It's NOT like the older CIS system on some vehicles
where the pump is powered for a few seconds at the "run" position.
So what's with this 911 forum that posts by many are usually misleading,
which is not the case on the 964/993/986/996 forums on Rennlist?
Bottom line: This 911 forum is becoming like the "dark side" forum not
only with misleading info but with gratuitous personal slams.
- douglas bray -
#48
I haddah Google dat
Loren,
You are an odd little duck. An odd little irritable duck with an overly active imagination. I have no idea where you constantly pull these one in a million scenarios from in order to try to criticize others, and yet you never give any useful input, ever.
You should cut back on the Dexatrim. Your manic posts are getting really odd, even for you.
#49
The thing is, Loren knows quite a few things more than anyone around here.
He might not want friends or to look cool, which is fine with me.
He could be a child molester posting from the prison library, I don't give a **** as long as the info is accurate.
Sure if you had to choose who to get info from on the phone based on personal feelings you wouldn't pick Loren over Pete or Steve. But he is the authority on Bosch as far as I know.
Don't get me wrong, If I he pissed me off I'd be a little tweaked also. But I try not to live vicariously through a 19 inch flat screen.
#50
I haddah Google dat
That's ok with me J Brinkley.
If you can keep licking Loren's boot and will wait for a golden nugget of wisdom to randomly fall into your lap, then more power to you. I choose to use Rennlist as a learning and dicussion forum. Not a competition to see who is the mostest rightest. I pretty much don't care if Loren shows up or not because most of the time his posts are just wing ding cutdowns straight from the Dark Side.
If that makes you better and me living vicariously through a computer screen, then so be it.
#52
Team Owner
I find the whole thing quite funny .. it is Friday afterall. It is true Loren knows his stuff, he is also quite the ******** , and i am sure he would be the first to admit it. But i do find it pretty funny to read. .. most of us know which posts are right and which are wrong and correct people in a little more polite fashion. i don't hold anything against anybody but you gotta give the guy credit, he has some pretty funny zingers.
#54
Team Owner
you guys crack me up
I'm getting a beer and going to watch death race .. there is a 911 in it that gets totally wasted .. you gotta watch to find out how ! ... it's friday
#55
The whole thing about Lori is that after seeing 'its' excrement for a few years now, you pretty much figure out 'it' is a COMPLETE A$$HOLE and really has no place interacting with the public. It just makes me sick to see its holier-than-thou posts and insults to almost everyone on a given thread.
Oh, I forgot....Sewer Troll Alert in effect!
#56
"I choose to use Rennlist as a learning and dicussion forum. Not a competition to see who is the mostest rightest."
- rusnak -
Really? Or use it to start or continue (pile-on) personal attacks/slams like a
few others here and what typically occurs with many other "brain dead" ones
on Pelican, i.e. attack anyone that expresses a conflicting view.
Ever wonder why you (ace) and some others here are singled-out and shown
for what you are, an incompetent Porsche owner whose posts ruin Rennlist for
all by making gratuitous attacks/slams? Maybe read how some threads begin
and what's initially posted. Or are you and some unable to correlate how a
thread evolves in response to gratuitous attacks and are you and others
really totally brain dead?
Remember, What goes around, comes around!
- rusnak -
#57
The funny thing is this sick little being, whatever it is, doesn't even know that he's the one who slings the first mud. Lori, can't you figure it out now? It's you that is the problem, just ask the HUNDREDS of people here and on Pelican who you've attacked/insulted. Go molest frogs or some other unsuspecting creature.
#58
I haddah Google dat
- rusnak -
- rusnak -
Loren, you do almost NOTHING BUT LEVEL PERSONAL ATTACKS.
What about your own actions do you not comprehend? Haven't you learned by now that people are responding to what you write? Try cutting out the BS and I'll bet you that the way people respond to your posts will change 100%.
Go ahead Loren, I am making you a challenge. Try being curteous and you'll see that people will treat you with respect and fairness. But, if you continue to sling sh%t at people, you can bet that things will get worse for you. I'm merely stating a fact, not making a pejorative statement. Everyone, and I mean EVERYONE has no problem with you except for your INSULTS. You are the LAST person who has any room to talk about this.
