Also where did you find your duck tail. I too have an SC and am looking for a tail.
I think I posted that the duck tail is an MA Shaw (same as Getty) and is excellent. My install time was less than an hour with a very good fit and no cutting or heavy sanding. That did not include the paint prep or painting which again was painless. Did you also want a picture of the small whale tail I took off and want to sell? Jack
Do the fasteners/brackets I've drawn red boxes around in the pic below (thanks Peter) have a part number?
I have a tail, but those brackets are not present.
As per rusnak's post, the brackets are called angles. Be aware that the middle three are the same, but the outboard ones are different than the others, so you will order "3 + 1 + 1"...
