Headlamp H4, HB5
two headlights, two plug adapters, a relay kit, two new gaskets, two bulbs, two screwdrivers, wire strippers.
If I ever did that again I'd get some plastic covers also. lenses use to be $40 but I bet they're more now.
Considering how spendy they are I would insist on the relay kit.
It's very simple, I bet there's a how to on pelican, here actually http://www.pelicanparts.com/techarti..._headlamps.htm
Here are my experiences: H4 Upgrade
Here are multiple posts on the subject: H4 Upgrade
Good luck.
Ian
Good luck.
Ian
Even better....
My '78 Targa was upgraded to H4's several years ago and just last month I upgraded the H4 halogen bulbs to 35W 4300K high/low HIDs.
Wow, what an improvement.
The bulbs in the HID kit I purchased had integral attached shading/apperture fixtures so these had SHARP upper beam CUTOFF in the low beam position to reduce glare for oncoming drivers.
