Replaced Turn Signal Stalk...Now Headlights Don't Work
I replaced my turn signal stalk today because the old one was broken and the high beams kept coming on by themselves.
Tried everything out and now the headlights don't work.
I checked everything and it seams that I am not getting voltage through the headlight switch (connection no. 56). If I bypass the headlight switch (power straight from key switch to turnsignal stalk) the headlights work.
So I guess the headlight switch needs to be replaced now. Why would that happen though? Could something have gotten damaged when I removed the headlight switch to install the turnsignal connections?
When I bypass the headlight switch, the headlights work. And the high/low beam switch works too.
I have a new headlight switch on the way. So I guess I will know for sure if that is the problem when I replace it.
Did you pull out the headlight switch when you installed the combi
switch in order to access the wires more easily? The reason I ask is that I am thinking maybe you did and when you twisted the headlight switch **** off you didn't hold the shaft still while you did. If the shaft gets twisted too much the contacts inside the switch can be ruined. This is why there is a hole in the shaft so you can hold it still with a small pick or something. If you didn't remove the headlight switch, I'd say double check your wiring against the wiring diagram, it's pretty easy to mess up.
However, I noticed today (I guess I didn't realize before because it was light out) that everything is really screwy.
In position no. 1 (off) the interior gauge lights are on.
In position no. 2 (parking lights) everything is on as if it was on position no. 3 (headlights).
And in position no. 3 (headlights) only the parking lights are on and the interior lights are off.
I'm hoping this is just the internals of the switch being screwed up.
Maybe it did get buggered up.
However, I have to say that I've been hand tightening my switch **** for about 7 years now. I've literally never taken the time to tighten it properly, and every time I turn my headlights on, I tighten it while driving. Based on this, you'd really have to work hard to break the thing.
However...I'll admit my stupidity here.
When I was taking off the headlight switch the plastic screw on ring that holds it in place was really tight. And I didn't have any type of spanner wrench to fit in those holes.
I thought, "well maybe if I turn the headlight switch by the stem I could loosen it that way". I tried it once, it moved slightly and I thought better of doing it that way.
I took an awl, stuck it in one of the holes and lightly tapped the plate in the loosen direction. That worked and was what I should have done to start with. But the damage may have already been done.
To be honest, I hope I did break it. Otherwise I'm going to have to electrically trouble shoot the problem to try and figure it out.
So as an update.
I replaced the headlight switch today and everything is back to normal.
Just for fun I tested the connections on the old switch and they were all messed up. I must have really f'd the switch up when I removed it.
