Should I remove my air conditioner?
I was puzzled about your post as at first I was thinking air cooled Porsche and how in hell the inside of one of those could accumulate so much moisture within the cabin overnight.
Then I noticed that you're driving a 996....
Your A/C itsself is causing the high humidity within the cabin each morning...!!
Stop using the A/C and the problem will go away.
"Yesterday", when you shut down the car for the day the A/C evaporator was thoroughtly clogged, saturated with moisture, due to the day's operation, even on a relatively low humidity day. Most modern day A/C evaporators will have as much as 10,000 square inches of evaporator vane surface area "squeezed" into as small of a space behind the dash as can be allocated.
Think SPONGE.
Once the evaporator is no longer being cooled that condensate will begin to evaporate into the CLOSED passenger cabin.
You can combat this problem, mostly, by lowering the windows 2 or 3 inches overnight.
Or retrofit the car using an EED from airsept.com
But you 996 also has what can be a fairly serious design flaw in the climate control.
During the summer months once the climate control has cooled the cabin to with a few degrees of you setpoint some of the CHILLED airflow will be routed out of the windshield defrost/defog/demist ductwork. within an hour or so this can so thoroughly CHILL the windshield that on a relative humid day condensation will begin to form on the OUTSIDE of the windshield.
No biggy, right, just turn on the wipers....
But not if it's early evening, nearly dark, you've just driven through a rainstorm in AL in July and the windshield then fogs over so quickly you don't realize soon enough why your forward vision is/has declined so rapidly.
I have developed the practice of selecting and then deselecting the windshield air outlet flow path anytime I start the car and I have the A/C compressor clutch enabled.
Think SPONGE.
KC911,
I have already removed my AC and heater fan and ducting, and I am re-installing heat with -74 heat exchangers. Do you know what parts I need on the topside to complete the heat?
Keith
'88 CE coupe
Keith, where did you source the 930 air duct sheet metal? New or used and what did it cost you? Was it a direct bolt-on or did you have to modify the fan shroud? Looks like a nice mod. My blower is not hooked up anyhow..........
How does AC removal devalue a 1987 Carrera when the 21 year old system doesn't perform well enough to cool the car? One either repeatedly spends 100's to 1000's of dollars repairing and maintaining an obsolete R12 system, or updates to a newer R134a system. From a performance and cost standpoint, taking it completely out is a net plus. Even when new, the AC system was mediocre.
If all the components, including hoses, are in good working order, it doesn't costs hundreds or thousands to maintain it. The only cost would be the annual recharge.
However, if it's a choice between a car with A/C removed and a car with non-functioning A/C in place, I don't think there would be much difference. In either case, it will cost a great deal of money and/or effort to end up with an adequate system in the car.
Keith
'88 CE coupe
Provided you have a 911 has the extra condensor under the front nose, AND the blower to force airflow over that condensor is FULLY functional, (fuse not blown, no bird/squirrel/dirt dubber nests) the A/C operation will be satisfactory.
Otherwise I'm sure there is enough room under the engine lid mounted condensor to install two or three 12 volt "boxer" type computer fans that run any time the compressor clutch is engaged.
Keith
'88 CE coupe
