Should I remove my air conditioner?
I have a 1987 Carrera that is bone stock. It looks good and runs fine. The AC doesn't really work too well, and I usually just put the windows down in the summer any way. I am thinking about removing the AC to reduce the weight of the car.
How much weight will be shed?
Will I feel improved acceleration, braking, and handling?
Is this a bad idea on a nice stock vehicle?
I did and have no regrets whatsoever. Even though mine worked fine (when charged), I'm a windows down person and only used it a couple of time during my first few years of ownership. You'll save around 55 lbs (or so) on a Carrera, but the big plus is cleaning up the engine compartment allowing for easier access (I also backdated my heat - I recommend that too). I've kept all my components stored in my garage, but know I'll never go back
Keith
'88 CE coupe
Keith
'88 CE coupe
I just got rid of the rear condenser and the compressor. I could always put them back in if I needed to.
I doubt you will actually notice any difference in feel, handling, acceleration, or braking.
Resale value,... which you may not have an interest in...
Location....
If I were in Memphis, say, I would NOT disable the A/C.....
In regions with high temps and humidity I would do whatever was needed to get it to work reliably...!!
Location....
I live in Florida. My AC works as well as any other 911. Has a brand new condensor. I only run it to keep it working. Otherwise its windows down no matter how hot it is outside. I just can not bring myself to remove it. (in case I do sell).
If you take out your compressor and condenser you can always reconnect them when it is time to sell. It will just need a refill but seeing as they are non-barrier hoses then by that time it would have needed a refill anyways.
Don't do it. Leave it in.
I took the A/C (EVERYTHING) out of my 86 a couple years ago because the hoses were shot. I didn't use it anyway as it's not needed very often in Denver, and I like the idea of a less-crowded engine compartment. But now I really regret taking it out as the rest of the car is perfect or soon will be. I've decided to put it back in with new Rennaire evap unit, Procooler and barrier hoses. Having it in will restore more $ in resale value than it will cost for the replacement pieces. I don't intend to sell the car anytime soon but I'm sure I will some day.
If you do take it out, take lots of pictures and document what you did so you can use it as a guide when you reinstall it. And save every nut, bolt and bracket and label each one for its location.
Will 55 lbs (alone) be significant - no. But drop 150+ (as I have) from our "Carrera pigs", and you can absolutely tell a difference. Resale was not an issue for me and I don't use A/C in any of my vehicles. Cleaning up the engine compartment (easy access) was a big plus from my perspective. Only you can decide what's "right" for you. Here's my before/after from removing the A/C and backdating heat:
Keith
'88 CE coupe
Keith
'88 CE coupe
KC911 - Looks very nice. What else did you lose to get the -150 lbs?
I've been debating whether to get mine working properly, or pull it out.
You pic has swayed me more towards removal.
Leave it in! Not worth the trouble to put it back in as it will be very expensive with new hoses, recharge etc., etc. maybe as much as $1,000 or more to get it back in and running. When you sell this car, and you will, someday you will regret taking it out.
Keith
'88 CE coupe
I wouldn't agree with that having lived there for a few years. When I opened the doors to my car in the Am going to work, my sunglasses immediately fogged up every day 9 months out of the year. that place is HOT, HUMID, and STICKY. Ga isn't much better, but it is better
