What have I done to offend the gods?
After reading some of the posts about their 911's not starting I thought.....that will never happen to me..... I don't work on it.
It's only when I touch wrench to a car do they stop running.
I had a fellow coming over to take a look at my beauty for sale.
Guess what?
I just ordered two DMEs and two fuel relays. I like two of everything.
I called the guy and asked if we could have a redo.
I hope one of the relays is the problem.
Damn
Guess what?
Damn
Guess what?
Damn
Guess what?
Damn
The latest is I just recieved my DME relay, it didn't help. I also changed out the fuel relay. It still will not start..........darn it. The old DME states 15amp. The new one is 30amp. I will call the supplier and see whats up.
I will next check the fuel pump, to see if it is pumping. I suspect when I remove the plate covering the pump, I should, with the ignition on, be able to feel it vibrating. Is this correct? I am not mechanicly inclined.
WHATEVER YOU DO - MAKE SURE THAT THE CAR IS PROPERLY SUPPORTED ON A LEVEL FLOOR, AND IF THE REAR WHEELS ARE DOWN MAKE DARNED SURE THAT THE CAR IS IN NEUTRAL!!!
Neri: "Doesn't the engine have to be cranking to for the fuel pump to engage?"
EDIT BY AUTHOR:
I originally wrote:
"Nope. Not on an SC (or other CIS cars). You just turn the key to "ON" and the fuel pump comes on. Audible whining noise.
Does this not happen with a Motronic car? Peter?"
I have ben corrected. The whining apparently is the ignition module. The fuel pump does not engage until the starter is cranking."
EDIT BY AUTHOR:
The thought was to prevent pumping gallons of raw fuel out of a torn-open gas line. The system functions via a sensor plate/housing switch on CIS cars (including Turbos), and is handled through the electronics on 3.2 liter cars.
Over many years at the shop I saw some 911s that had been in horrific accidents (unfortunately some involved fatalities), and I can not recall a single car that caught on fire because of an accident. Pretty remarkable.
If your pump runs with the ignition on, I strongly urge you to diagnose the system and correct any problems!
I haven't started yet
I was reading on the Pelican website tech section, where I can jumper from number 6 fuse and touch #5 or #7, on the bottom of the fuse terminal and it will bypass the safety and make the fuel pump run. Anyone done this and is there a downside?
