911 Forum 1964-1989
What have I done to offend the gods?
Old 01-13-2009, 10:06 PM
  #46
GothingNC
GothingNC's Avatar
Originally Posted by theiceman
I needed an idler roller for my audi and got it from the dealer , it had both an Audi and a VW symbol stamped on it. I inquired and the guy says if we look it up in the audi parts list it costs more. on the VW price list it costs less...
go figure..
Iceman,
Just found a thread on the 996 forum someone using a VW ignition switch part in their 996 for only $30
John
Old 01-13-2009, 11:50 PM
  #47
Lorenfb
Lorenfb's Avatar
"Cal, I missed the part where you diagnosed the "no spark" condition. How did you test that, and did you see if you are getting power to the fuel pump by jumpering the dme relay socket?"
rusnak
If it's a "no spark" condition, let's not have the troubleshooter testing
for power to the fuel pump. Using the "shotgun" approach to troubleshooting
wastes time and can potentially waste mone!
"I have read the injectors can short out and cause a no spark."
Not actually. An injection short can result in no injector signal but it won't
affect the spark.
Here's a very simple test procedure you can use without your DME ECM:
1. With the key "on", check that pins 1, 18, & 35 all have 12 volts,
i.e. best done with a basic test light ~ $10-$15. Check for ground
at pins 5, 16 & 17.
2. Using an ohmmeter, check for approximately 1000 ohms between
pins 8 & 27 and pins 25 & 26. Then with a voltmeter set to A.C. volts,
check that the A.C. volts between pins 8 & 27 is greater that 1.0 V.A.C
while the engine is cranking. Then check between pins 25 & 26 for about
.100 V.A.C. when cranking. Make sure that the sensors are NOT reversed
at the engine bracket.
3. Again using the test light, make sure the coil has 12 volts.
4. Once the DME ECM is re-installed, remove the coil wire from the
distributor cap and place it about 10mm from the engine case.
5. Have someone crank the engine while using the test light to check
for a signal at one of the two coil connections. If you get a flashing
signal, then check that the coil wire has a spark.
6. Next remove an injector connector and check for 12 volts.
If you have an injector tester (light), you can test for injector
pulses while cranking.
Report back once you have done the above.
Note: As mentioned previously, your DME ECM is NOT the problem!
Old 01-14-2009, 12:27 AM
  #48
rusnak
I haddah Google dat
rusnak's Avatar
you're the one assuming he has no spark. I was asking how he came to that conclusion, as you have already quoted me. And he already changed the fuel pump at this point, what money wasting are you referring to exactly?
Old 01-15-2009, 11:02 AM
  #49
cal44
cal44's Avatar
I thought while waiting for the DME I would ad a little information. I thought I would remove the old Clifford alarm (have I posted this already?).
This is a heads up for anyone that has old after market items such as an old alarm. The electrical tape is 25 years old and after years it turns to a goo like substance if not applied correctly.
I found wire connections with little wrap on them and (of course) they were non factory wires.
Oddly, I was walking my best buddy and saw a fellow about my age (not so young) working on installation of a hands free in a car at the neighbors.
Turns out he is a Porsche guy and has been in the auto electirc biz since the eighties and he does mobile so he comes to the house.
I am going to have him clean up and remove any non factory item from the the car.
So this non start led to the discovery of wires that may have cause me problems in the future or now, for all I know.
Funny how things work.
Old 01-15-2009, 12:51 PM
  #50
Peter Zimmermann
Peter Zimmermann's Avatar
cal: I would have suggested that you look for old alarm components (especially in the trunk under the cowl, and under the passenger foot board), but that usually only applies if the battery has been removed, then hooked up, then the crank but no-start happens.
Clifford's were pretty reliable, but I've seen some horrible installations!
Old 01-15-2009, 03:21 PM
  #51
cal44
cal44's Avatar
Just got a call from Otto's. Nothing wrong with the DME. So as soon as it gets to the house I will have the tech drop over. He thinks as "Mr. Z" that it may be the old Clifford as they used to install to where it would not start. Will report in a week. Tired now
Old 01-15-2009, 03:43 PM
  #52
Peter Zimmermann
cal: Don't forget about post #37 of this thread - that was a serious suggestion!
Old 01-15-2009, 04:55 PM
  #53
rusnak
I haddah Google dat
rusnak's Avatar
well that is good news, Cal. Hang in there, it'll be running soon.
Old 01-15-2009, 07:48 PM
  #54
cal44
cal44's Avatar
Mr. Z, got it....post 37. I will say that I released the nut on the fuel rail and fuel came out and when I put in the new fuel pump I had my share of fuel in my face. Then I discovered hose pinch pliers.....duh.
One more thing, when I turn over the engine I can smell fuel at the tailpipe. This is a good indicator of my desire to own and drive these cars. In the past if a hobby car gave me this kind of trouble I would have sold it "now". But these darn Porsches have gotten under my skin. Signed, an Addict.
Thank you Rusnak
Old 01-17-2009, 10:37 AM
  #55
cal44
cal44's Avatar
Got the (good) DME back from Ottos and will install this afternoon. Electric tech to be out on Tues. morning to remove 25 year old items I didn't invite. I have decided not to touch anything further until tech looks. Then we will see.
Old 01-20-2009, 06:24 PM
  #56
cal44
cal44's Avatar
Here is the latest. The tech showed up and had the car running in one hour. What was it? The old non factory alarm. Wires with electrical tape falling off. He is getting rid of all non factory items and fixing what past fingers had done. The good thing is this guy knows Porsches. Talk about dumb luck running into him while walking my dog.
Heads up for those with old alams. As soon as the noodles (I can't spell spegetti) were cleared out the six sprang to life. What a relief. Thanks all all that helped. I got new parts I didn't plan on buying but whata ya gunna do? I will report on Pelican as those folks were helpful as well. Mike
Old 01-20-2009, 06:50 PM
  #57
Ed Hughes
Ed Hughes's Avatar
Wow, glad to hear it was that.....oh well, you got a few new parts on her now that won't fail for a long time. Now, get out and drive!
Old 01-20-2009, 06:59 PM
  #58
theiceman
Team Owner
theiceman's Avatar
Received 1,120 Likes on 802 Posts
well another success story. none factory alarms suck.
Old 01-20-2009, 07:05 PM
  #59
cal44
cal44's Avatar
This guy is something. He even puts little foam goodies on the doors edges so they will not chip if the door hits the wall. I really can't afford to have him remove the alarm from the other car but I really can't afford not to considering what happend. Thanks again guys.
Mike
Old 01-20-2009, 07:08 PM
  #60
theiceman
Team Owner
theiceman's Avatar
Hey Mike have we seen pics of your car yet ? maybe I missed em
Quick Reply: What have I done to offend the gods?
