Temp Switch Wire Question
There is a Temp switch on the cam chain cover of CIS cars... Mine is an 83 SC. The switch has two wires that connect to it.. The male end on the switch has a round raised button on it (see attached)
Here is my issue, the terminal broke off the wire. Where can I find the wire terminal end. I cant find one anywhere that will slide over that raised round button. Any ideas?
A replacement terminal doesn't have to be the right angle type, a straight one will also work (you might have to fabricate a short extension for the wire). Try a stereo installation shop, they usually have a big supply of many connector sizes, some amps probably have terminals that use that size.
