911 Forum 1964-1989
911SC Valve Adjustment Problems
Old 10-20-2008, 03:45 PM
shimmey
shimmey's Avatar
Unhappy 911SC Valve Adjustment Problems
I just finished adjusting my valves on a 1982 911SC. I also replace the cap, rotor and plugs. After reinstalling the valve covers and filled engine with oil I attempted to start...engine would just turn over and not start. I felt that I needed to readjust the valves so I again took off all the valve covers and removed the plugs. I am unable to turn the engine over on the pulley to line up TDC. It is as if the engine is froze. The pulley belt is tight and plugs are out. I tried to loosing up a few of the valves that are depressed but to no avail. Do you think I bent a valve? Any help would be appreciated.
Thanks.
Mike
Stillwater, Minnesota
Old 10-20-2008, 04:55 PM
old man neri
old man neri's Avatar
I don't think it possible to bend a valve by a poor adjustment.
I would have started with the easy stuff first such as; Did I plug all the leads back in, are they in the right order on the cap, are they on the right plugs, did I accidentally unplug anything when I was reaching around in there...etc?
Also, did you do it the normal adjustment method or the backside method?
-matt
Old 10-20-2008, 06:07 PM
shimmey
shimmey's Avatar
Default 911SC valve adjustment
Thanks for the help Matt,
I agree with you that having the possibility of the plug wires in the wrong order or disconnecting something around the engine could cause it not to start but my biggest concern now is that I cannot turn the engine over.
Thanks,
Mike
Old 10-20-2008, 06:32 PM
old man neri
If the belt is slipping just try squeezing the belt as you are trying to turn.
Old 10-20-2008, 08:13 PM
porsche930dude
porsche930dude's Avatar
Good lesson for all. Do one thing at a time. You didnt turn the engine ccw did you?! Could be the chain tentioners binding up if so
Old 10-20-2008, 08:49 PM
shimmey
shimmey's Avatar
Hi all,
Did not turn CCW, have hydraulic chain tesioners, squeezed belt as I tried to turn, belt is not loose at all.
Mike
Old 10-20-2008, 08:59 PM
shimmey
shimmey's Avatar
How about if I put the plugs back in and tried to crank it over or could I make the problem worse....MIke
Old 10-20-2008, 09:32 PM
tyro
tyro's Avatar
just talking silly here..is the car in gear with the ebrake on?
Old 10-20-2008, 09:55 PM
theiceman
Team Owner
theiceman's Avatar
Received 1,149 Likes on 823 Posts
Funny Tyro that is just what I was thinking but didn't want to ask .
Old 10-20-2008, 11:06 PM
shimmey
shimmey's Avatar
In neutral parking brake is off...Mike
Old 10-20-2008, 11:22 PM
tyro
tyro's Avatar
Have you tried going anticlockwise SLIGHTLY to see if the thing turns?
With the plugs out it should turn rather easily.
Old 10-21-2008, 12:03 AM
shimmey
shimmey's Avatar
A friend of mine who is well versed in 911's suggested that I try slight ccw. Engine would not turn in that direction either. You would think with the plugs out that the engine would turn easily.
Old 10-21-2008, 12:58 AM
tyro
tyro's Avatar
Since you're in Stillwater - any chance you have had some work done at Auto Edge?
Might be worth giving them a call..but it makes no sense to me why taking the valve covers off after it turned over would prevent you from turning it by hand.
Maybe you were missing a wrench, socket or a piece of hardware from the covers?
Old 10-21-2008, 07:29 AM
newsboy
newsboy's Avatar
Did you by chance, turn the engine counterclockwise? I have read that doing this can damage the chain tensioner. I also believe that in some SC models, the distributor rotates counterclockwise. I mention this, because it would effect your valve adjustment.
Old 10-21-2008, 04:25 PM
abe
abe's Avatar
Default I am dying to find out what is wrong....
..since I will probably adjust my valves in the future.
abe
Quick Reply: 911SC Valve Adjustment Problems
