911 Forum 1964-1989
Smog Passing Issues?
Old Oct 12, 2008 | 01:35 PM
  #46
Ed Hughes's Avatar
Ed Hughes
[QUOTE=TT Oversteer;5892821]
So it sits in the garage with no plates waiting for the state of CA to get its ****e together. It is illegal for me to operate the vehicle even though is meets current smog standards. And did I mention they have my money?..............
[QUOTE]
Friggin **** bastards! They tried to suck a bunch of money out of my wallet when I registered my Ridgeline, which I'd bought in Texas less than 90 days before we moved. The drone at the counter kept citing the rules. I countered they were clearly in place to prevent Calif people buying cars out of state and skating on the premium tax Calif gets. The fact I clearly lived in TX when I bought the vehicle should get me a pass on this. Well, remarkably, after working my way up the level of drones at the DMV, I actually found a supervisor that applied common sense.
The final here is they keyed in a higher GVW on the truck and overcharged me-they did catch the error and sent me a $100 refund.
Originally Posted by KC911
Althouogh my car is now exempt (here in NC) when she wasn't, she could pass w/o a cat either. My Fabspeed europremuffler (with O2 sensor in place) looks close enough to a cat that most non-911 guys would think it was one. Most inspection stations around here (LOTS to choose from) probably never see a vintage 911...I remember one having "no clue" as to where my carbon canister was until I pointed it out to him. I'm with Ed on this one...she's a "toy", and is insignificant compared to the gross polluters...I sleep OK .
Keith
'88 CE coupe
That is a benefit of Fabspeeds parts. I'll take you one further on no clue. The last time Ruby went in for a "civilian" inspection in Texas, the young goof that was commencing to inspect the car asked me: "is this one of the years that they put the engine in the front?"
Originally Posted by holy911
Did she pass the first time through or did you have to perform some repairs? Where was the car from? Cats in place?
Brought her with me from Texas when we moved back. When I get her plates, the move is complete.
Old Oct 12, 2008 | 03:40 PM
  #47
TT Oversteer's Avatar
TT Oversteer
I've heard several of you state that your cars pass smog without a cat. When going through my situation I had two different shops plug in the gas analyzer and sniff the exhaust before and after my repairs. Both said "ok" your car is clean enough to pass smog. BUT when I went to the referee and he put it up on the rollers and put the car under load it failed miserably (twice). I think not all counties in CA require the dyno test with the car on rollers and running under load. I think that is the difference here. Trust me, your 3.2 will NOT pass smog in "enhanced" counties requiring the rolling test without a cat.
Old Oct 12, 2008 | 03:59 PM
  #48
Ed Hughes's Avatar
Ed Hughes
My '84 passed TX smog with no cat on a dyno, my '91 928 had issues-go figure. Can't remember specifics, but TX certainly wasnt lax in their expected numbers.
Old Oct 12, 2008 | 04:05 PM
  #49
old man neri's Avatar
old man neri
[QUOTE=Ed Hughes;5893396]
Just be happy he didn't confuse rear wheel and front wheel drive when he put it on the rollers. That would have been ugly.
Old Oct 13, 2008 | 04:52 AM
  #50
holy911's Avatar
holy911
Whoa, dyno test for smog?! I guess I'm lucky here in San Jose (Santa Clara Co). We have an idle and cruise speed test (RPMs ~3000, I'm guessing here). And the usual check for presence of gas filler restricter, cat, whatever else.
Old Oct 14, 2008 | 12:32 AM
  #51
Antony.'s Avatar
Antony.
I've put mine through smog twice now in Mt. View and San Jose... both times it was on a rolling rear wheel test rig(dyno). Always scares the crap out of me to watch these hacks perform the test when I think what would happen if those rollers jammed for some reason.
Old Oct 14, 2008 | 12:59 AM
  #52
holy911's Avatar
holy911
You have to do a dyno too? I'm in San Jose and have never had to do that. Is this a requirement for older cars? Even with my 96 Subaru its just the idle and higher RPM static sniff tests. Must be after a certain year or the age of the car.
Old Oct 14, 2008 | 01:10 AM
  #53
Antony.'s Avatar
Antony.
I believe so. They've sent me to test only stations for rolling tests 2/2 times now.
Old Oct 14, 2008 | 01:27 AM
  #54
old man neri
Roller tests up here as well.
Old Sep 15, 2010 | 08:44 PM
  #55
rusnak's Avatar
rusnak
I haddah Google dat
1984 3.2 911 with > 300k miles.
Preparation:
Half tank of Chevron premium, BG44K fuel system cleaner, valve adjustment, new cap and rotor, new fuel filter (important), new-ish cat, old (50,000 mile O2 sensor), and re-connected the brown wire next to the dme labelled "Bridge to ground" in Bentley. The car was running at .97 to 1.03 lambda at steady speed on the highway. The spark plugs are about 6 months old, and the wires are too old to remember. I bought a new gas cap from Napa Auto for this test, which is non-venting. I didn't know this until I was about to have the car tested.
The car passed with a good margin to spare.
Here's the test report:
File Type: jpg
Old Sep 15, 2010 | 09:02 PM
  #56
Ed Hughes's Avatar
Ed Hughes
Next weekend I'm doing "exhaust work" in prep for mine.
Old Sep 15, 2010 | 09:07 PM
  #57
Pavegeno928's Avatar
Pavegeno928
I'm military and may be headed to Europe next summer. Anyone know if I will have to pass a smog test when I bring the 911 back to the US regardless of the returning state? I don't have a cat but do have an O2 sensor.
Old Sep 15, 2010 | 09:13 PM
  #58
Ed Hughes's Avatar
Ed Hughes
Each state has it's own rules. Nobody can answer that in a general sense.
Old Sep 15, 2010 | 09:18 PM
  #59
Pavegeno928
I was looking more to see if there is a "federal" smog inspection at the ports of entry before you can retrieve your car and introduce it back into the USA. In other words, if you brought the car back into a port whose state does not have a smog inspection, is there still a federal inspection?
Old Sep 15, 2010 | 10:21 PM
  #60
Ed Hughes's Avatar
Ed Hughes
The only Fed issue, I would think, is that it was built to US standards. If it is a US car, it had to have been built to them.... but there may indeed be an inspection or sign off to ensure it comes back in as per the stock specs, but I don't think emissions would be part of that.
Others here may know.
