911 Forum 1964-1989
Shift knob replacement question
Old Aug 17, 2001 | 07:47 PM
Face's Avatar
Face
Question Shift **** replacement question
I'd like to replace my shift **** with a Momo **** I recently ordered. What's the best way to remove the factory **** on an 89' Carerra? Is is simply screwed on or bolted in somehow? I know this sounds silly, but I'm new and trying to be careful!
Thanks.
Todd
Old Aug 17, 2001 | 08:05 PM
richard glickel.'s Avatar
richard glickel.
Post
Toddface,
I think you'll need something called a "crush sleeve" to remove the stock ****.
There was a tech article on this very subject in either Panorama or Excellence within the last few months (sometime this year). It's not a terribly difficult task, just requires the correct tool.
Good luck!
Richard
'87 Carrera
Old Aug 17, 2001 | 08:29 PM
Avenger6's Avatar
Avenger6
Talking
The "crush sleeve" is what holds it ON! To get the old one off, you just have to pull it straight off. It will take some force, because it is a friction fit, via the crush sleeve, that holds it on. Just tug hard. The only thing you might damage is the old *** or the old sleeve, neither of which you will need. I have one of the MOMOs installed, and it is great. It is held on with set screws - much more secure than the crush sleeve, and easier to get off when needed. Enjoy
Old Aug 17, 2001 | 08:32 PM
George 86T's Avatar
George 86T
Post
Todd--get a 15mm end wrench which will fit around the gear shift shaft under the **** and then tap upward smartly. The **** is a wedge fit.
Old Aug 17, 2001 | 09:41 PM
fsinapi's Avatar
fsinapi
Post
Sorry to disagree, but according to my Bently Service manual, the shift **** on the 1987 - 1989 Carrera is held on by an allen bolt. You should be able to pry the cap from the top center of the shift ****, and then remove the allen bolt. I'm interested to know how the new **** fits, as my 88 Carrera could use one, but many I see advertised are only good up to 86.
Frank
'88 Carrera
Old Aug 17, 2001 | 10:23 PM
ked's Avatar
ked
Post
Frank is quite correct - I just replaced the oem shift **** w/ a very nice momo (picked up at rennsport - hey, the vendors were great weren't they?). pop off the plastic center cap (w/ shift pattern), remove allen bolt, tap off old **** (gently, from bottom lip), and follow momo instructions... all as described for G50 trans in 87-89 models in Bentley manual.
Old Aug 18, 2001 | 10:43 AM
Avenger6's Avatar
Avenger6
Post
DOH! I didn't consider that the G50 Xmission would have a different way of holding on the ****. SORRY! The pull off/use 15mm wrench method is good for 915 equipped cars.
Old Aug 18, 2001 | 11:33 AM
Face's Avatar
Face
Post
Gents,
Frank and Kevin were correct! After about 5 minutes of pulling and tapping I decided to pop the cap off. Sure enough, a hex bolt held it in place. The new Momo **** was on in about 3 minutes and fit/looks great.
Cheers,
Old Aug 18, 2001 | 01:01 PM
Mrdi's Avatar
Mrdi
Post
Correct re: allen set screw.
Caution...The Momo's mount with set screws that put 3 indents into the shift lever to secure themselves, unlike the the stock **** that screws down. I did it and didn't like it now I have three small sharp indents on the shaft. The Momo's are bushed w plastic inserts to accomodate the different dia.'s.
The system is not as substantial as stock.
Wasted $50.
