Radio Codes '88 Carrera
I pulled the radio, but did not disconnect any electrical leads, from my '88 911. Now the radio will not work. It has power but won't display a station or make any sound other than static.
The radio code form is blank so I'm not sure if it had a theft code and wouldn't think I had tripped it if I didn't disconnect any wires.
Any thoughts on this problem?
If it was a code problem it would display code on the radio. You also would have no sound at all, not even static. I would disconnect power and reset the radio. If you get static but no station display, that is an internal problem in the radio.
