78 911 SC Euro rear spring plate bushings
Attempting to insall Neatrix rear spring plate bushings. The outer fits in the cover plate and over the T-bar cover fine. The inner does not fit in the corresponding bushing well in the car. The well on the car is conical and the bushings are cylindrical. I installed a set of conical rubber OEM bushings PN 644-333-131-00 but they are too small in dia and I have play and what is worse, the spring plate bolt heads will rub against the body. I really d/n know what to do here.
FYI the car has been mostly disassembled, everything cleaned up, repainted, whatever so I am working with either clean or new components.
Thanks in advance for any help and comments.
Rob
Rob
