911 cam timing "walks" whi I torque nut
I am setting cam timing on my 3.0 SC engine. Everything is going fine except when I torqe the big cam retaining nut to spec.
My spec is +/- .1mm... but the setting "walks" more than that... and what's worse, it does not consistently "walk" in the same direction... sometimes its lower, sometimes higher... so I can't seem to correct for it.
My chain sprocket is brand-new and the lock pin fits very tightly... I just cannot believe there is that much slack...
What's up?
What's up?
Common problem - you have to counter the torque applied by equal and opposite force using your holding tool. Hold your torque wrench and holding tool close to each other, and torque your fastener by squeezing/pulling them together. If it still moves you will have to move your pin to the next hole and try again...
Thanks... I was afraid you you we're going to say that... so far that is the concensus....
Good side... I'm not doing anything wrong
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Bad side... I'm not doing anything wrong
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
Guess I could waste ALOT more time doing something alot more productive... but if that's the game then, I'm ok with it....
Just don't want to feel I'm much more stupid then I usually am...
On paper it should lock... why does torque on a fixed system with a thrust washer create so much radial movement?
The gogs seem to be fixed together.... is it flex in the chains?
It doesn't lock. It just puts you in the neighborhood. Watch your dial indicator as you tighten and counter torque. You don't want it to move. There will come a point where you just got to give it hell with the torque wrench, and then hope that you are in spec. Fortunately, you get better with the second try, then the third, then the..... ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
But when you do get it right, you are stoked!
But... for extra credit.... why does that system cause that problem?
I'd expect the pin to hold everything in state...
Why does torquing the nut cause things to move?
What is the soft-point?
I'm thinking the timing chains...
Theories welcome...cause, boy I'm curious
Good to know I'm not doing anything wrong...
Hey... I got nothing better to do the next 8 hours of my life.
Like Seattle said, when it's right, and torqued, it's a really good feeling!
Believe it or not, there is enough movement between the chain wheel and the cam gear, even with the pin in place, that you might think that you're OK, but the pin actually belongs in the next hole. If you have a tool in place that simulates the action of a tensioner the chain will have no effect on timing. Have fun with it!
JCP911S,
While I can't give you any technical advice on your issue I just HAVE to commend your 'Bulldog' approach to 'getting it RIGHT'!.
Kudos to you my man! You are really asking the right questions and 'digging' to make sure you do a proper job. Hang in there and good luck. You've got some GREAT folks looking over your shoulder.
Barry
Barry
Toby
