Rubber window track question
Spent the day fixing the passenger window on my SC coupe; it keeps falling off the track-any suggestions to keep it on??
PS. Is it me or are the window switches on this car crappy??
I had the same problem. I put a clip on the track to prevent it from moving off the two rollers. I used a clip that you would get from Autozone, etc. So far, it works great!
My car is a 1987 so I think it is similiar to SC window track, but am not sure.
Good luck
Good luck
If your problem is the glass is falling out of the track and sticking to the felt, I put silicone in the rubber which holds the glass. I closed the window and let it set. It dried and the window stays in the rubber which is on the track. I was rereading the post and am not sure if the track is coming off of the rollers or the glass is coming out of track?
Thanks, Rice
Thanks, Rice
