911 Forum 1964-1989
Climate Control relocation
Old Jul 29, 2008 | 07:18 AM
nyne11's Avatar
nyne11
Default Climate Control relocation
I am considering moving the head unit down into a new center console and am thinking of filling the hole with the Climate Control and other bits from the original location similar to the 993 setup. anybody see any real issues in doing this apart form the obvious in not sticking to original.
File Type: jpg
Old Jul 29, 2008 | 11:25 AM
Dan Cobb's Avatar
Dan Cobb
The Ancient One
Rennlist Lifetime Member
Wire length is probably the only part that will cause you issues.
Of course making the filler panel and doing the ****/control layout will not be straightforward, but other than that.....
It is yours, do it if you like it.
Old Jul 30, 2008 | 05:18 PM
spence88mph's Avatar
spence88mph
clever photochopping Dave, as Dan said I think the only issue will be extending the wires.
You can use a factory radio delete plate and drill the ***** though it:
http://www.pelicanparts.com/cgi-bin/...&I1.x=0&I1.y=0
Old Aug 1, 2008 | 09:53 AM
nyne11's Avatar
nyne11
Had another look at it and I think I will go with the radio delete plate and leave climate control basically where they are but below Head Unit.
File Type: jpg
File Type: jpg
Old Aug 9, 2008 | 01:40 PM
griffiths's Avatar
griffiths
Use care and caution when moving the ac thermostat (snow flake ****). If you bend, kink or break the aluminum capillary tube, between the evaporator and thermostat, gas will escape and the thermostat will not work (no ac); can't be repaired, only replaced.
Old Aug 10, 2008 | 03:44 AM
nyne11's Avatar
nyne11
OK.Thanks for the tip!
Old Dec 15, 2008 | 03:34 AM
nyne11's Avatar
nyne11
Default HELP!
OK............I removed the switch and it flew to pieces! Unfortunately while trying to reassemble it....................guess what.............I kinked the capillary tube and it's completely screwed now! Where can I get a replacement?..............Anyone got a spare they would like to sell me?....or is there a way to bypass the thermostat?
Dave............the idiot!
Old Dec 15, 2008 | 07:42 AM
psychoideas's Avatar
psychoideas
DAVE!
Hey, how are you? More importantly, where are you?
I'm in Newman in Western Australia. Playing in the construction game. I fly into Melb on the 19th. How long are you back for?
Old Dec 15, 2008 | 08:58 AM
nyne11's Avatar
nyne11
In Singapore heading for South Korea to escort a new Semi Sub back to Indonesia. Be home again on the 14th January. Good to hear from you Frank.
Old Dec 15, 2008 | 03:52 PM
psychoideas
Man, you get around!
Have a Merry Christmas where ever you are and stay safe!
Old Dec 16, 2008 | 08:27 AM
nyne11's Avatar
nyne11
You too mate..........and that goes out to all on the Forums here.
