Spark plug wires.
You could test the resistance value of each wire with an ohm meter. I don't know what the proper value is but someone on this board might know. If one is significantly different from the others that could point to a problem. I had a miss at idle and traced it to a corroded connector at the distributor cap. The wire itself was ok. I cleaned it which solved the problem temporarily but I do plan to replace the wire set in the near future as it is almost 20 years old.
I think I might take a trip down to Winnipeg tomorrow and see if I can get someone to do the CO thing for me.
Honestly the car drives fine but it just feels like it's not doing as nice as it use to. Hard to describe.
Thanks for all the help guys an gals,
-matt
Open up your deck lid in a dark garage while the engine is running and see if you see an arc'ing "light show". That should be a decent indication imo...
Keith
'88 CE coupe
Keith
'88 CE coupe
Okay,
So I called a recommended mechanic in the nearby city. He said it probably wasn't the mixture because somehow the O2 sensor would adjust the mixture if it was out of range and at full throttle it's a moot point because at that point it is just full rich. He also said it wasn't the plugs because if it was I would be feeling a miss. This I am not to sure about because I have replaced wires on other cars and felt an improvement.
Could it just be my imagination? Would changing the plugs make a difference? What kind should I get?
As for checking for a 'light show'...well I don't have a garage here and on week days I am normally in bed before it is dark out. I have long days and have to be up early but I will try perhaps Saturday night when I don't have to get up the next morning.
-matt
-matt
Personally, brother to brother, I think it is the airplane messing with your head. I think if you had say a chevy astro as your "other car" you would find the 911 to be doing just fine. Just 'cause the new plane can go light speed, don't mean everything can. Just one guys outside view.
Carrera?
clogged cat
clogged fuel injectors
intake manifold air leak
octane/altitude
head temp sensor
cap/rotor/plugs
valve adjustment
clogged air filter
AFM/MAF(?)
the list goes on and on.
clogged cat
octane/altitude
head temp sensor
cap/rotor/plugs
valve adjustment
clogged air filter
AFM/MAF(?)
The OE wires are pretty robust.
I would check that they are all completely seated ( the #6 is tough to reach and may b ethe first to suspect.)
Push them all until you hear a click.
If you decide you need new wires. The 8mm are not needed ( except maybe for extreme hi temp racing) even if they look better.
The plugs won't know.
TT oversteer-
I just read your post again. You may just be a acclimated to the liveliness of the 911.
Every fast car I ever had was fastest when I first got it.
Acceleration is an expensive and addictive drug.
Alright,
So I replaced the spark plugs themselves and ran some seafoam. It seems to have made a difference, the biggest difference came from the plugs. The electrodes were nice and clean but there was carbon all over the base. Also there was rust on the outside of the plugs. In any case the engine is a lot smoother now.
-matt
-matt
Before you waste your money on fancy ignition wires, test and clean the ones you have. If Beru, you can remove the terminal ends to inspect and test individually. And before you put them back together, use plenty of dielectric grease from Dow Chemical or Permatex.
Also, your engine sluggishness may be caused by worn out electronic fuel injectors. They can be cleaned, rebuilt or replaced.
ALso, buy a Bentley Service Manual to save money.
I've been changing my plugs, dist. cap and rotor every other oil change (oil change=3K mileslove having that fresh copper in there). Plug wires (Berus) are cleaned then, as well. I can ALWAYS feel a difference when the changeout happens...
Been considering removing the injectors and having 'em cleaned.
Glad it feels better for ya, Matt....was certain it wasn't the plane at all.
Best,
Doyle
Best,
Doyle
