Got a new car! (really just new Bilstein HDs)
I wish I could tell you how to test yours before you go to the trouble of removing. But honestly, everyone who "tested" mine said they seemed ok. Man, they were not ok. I'm not exaggerating, the Boge inserts I removed could be compressed with one finger and they didn't even think about rebounding.
The difference in handling is amazing. Far more improvement than I could have believed just a change in shocks could make. I made no other mods to the suspension (except a front strut tower bar).
Now that I know what I'm doing, I could do it much faster. But there were all the unexpected glitches like how the hell do you hold the top of the piston and turn the nut behind the air box when the nut has been on there for 21 years and I'm the size of a hobbit and really can't reach back there and have any kind of ability to torque it...
I would say it's a 5hr job for most first timers if you don't run into problems. 4 hrs if you have a clue what you're doing.
Does $1800 include the shocks? Lowering? Alignment? Corner balancing?
$600 or a little less for the shocks
$90/hr for 4hrs = $360
$300 for lowering/aligning (this can vary tremendously from one shop to another)
$1800 sounds too high to me. I didn't check with any shops. I just picked up a wrench and started acting like I knew what I was doing.
$1,800. is to much just to replace the shocks. I had mine replaced 2 years ago with Bilstein HD. I also had turbo tie rods installed, new front wheel bearings, an Elephant racing strut brace, and an oil change with Mobil 1. The total cost was $1,700. The car had 112,000 miles on it at the time. The rear shocks were shot and just self collasped upon removal. The fronts you could hand push and they would come back, but just bearly.
Thanks 911vet,
Do you have any picture of it, the way it sit now?
Thanks.
Thanks.
It does sit higher. I didin't measure before and after so I can't give you a quantitative answer. It is a noticeable difference. My car sat so low before, I had assumed the previous owner had lowered it below European specs. Now I know it was just sitting on totally worn out shocks.
I would like it to sit a little lower than it currently does. I plan to lower it and have it aligned after the Porsche Parade trip.
Way, way, way, way, WAY too much!
More than twice what I paid, about two months ago or Sports and HD's
In fact, my total bill from my wrench was LESS than if I had bought the shocks from Pelican and DID IT MYSELF.
....I wish I could tell you how to test yours before you go to the trouble of removing. But honestly, everyone who "tested" mine said they seemed ok. Man, they were not ok. I'm not exaggerating, the Boge inserts I removed could be compressed with one finger and they didn't even think about rebounding.
The difference in handling is amazing. Far more improvement than I could have believed just a change in shocks could make...
Keith
'88 CE coupe
911Vet/Shannon-
I can't agree more. My 89 Cab had original Boge's on it with only 33k, but they were shot in front and totally gone in the back when I bought it. I put the HD's on and new tires with the 930 tie rods with an alignment and was originally happy, but now after the tires/shocks/system has some miles on it, I am ecstatic. It is night/day difference.
Give your car some time and miles on the ride height issue. I thought my car looked like an SUV initially, but it has settled in well to it's original ride height before the change if not just a hair higher.
+1 on $1800 being too much. I had the shocks, tie rods and an alignment done for $1500 installed with tax, etc.
Jeff
Jeff
I'm jealous of your 930 tie rods. When I had a PPI done before I purchased, the shop said it needed new tie rods. I had them do the work before I drove to Atlanta to pick up the car. They said they would install turbo tie rods... got the car home and found out they installed OE tie rod ends. ARRRGGHH!!! I paid as much as turbos should have cost.
I do most of my own work now!
Great great tire from what I hear. When I need new rubbers I will either get those or the kuhmo SPTs.
So why did you choose the bisteins HDs and not the sports? I am still confused by all the differences. Some are meant for Bilstein OEs and some are meant for Boge OEs.....????
-matt
Edit: I had the tires of today and looked. Both front ones sage 'boge'. Does that mean I need to get boge replacements? And I think it might be time to replace them. They seem to be a bit oily.
-matt
As promised... before and after pics. After driving the car for a while, it settled and you can barely see a difference in the photos. The angle is slightly different and makes the after look just a tiny bit lower than it is. But, I can barely see a difference.
BEFORE (top) and AFTER (bottom).
