Suspension opinions needed
I've been going round and round gathering opinions and I've come up with a list of suspension upgrades for my 1980SC coupe.
My goal is to max out the available 8 points in the IS class in PCA. The total for the changes proposed is 7 so I'm under the max. I'm looking for opinions and insight before I pull the trigger. I only want to do this once so I've got to get it right the first time.
Rear
ERP Polybronze spring plate bushing
ERP Cambermax
Sanders 28mm Torsion bars 1 point
Smart Racing anti roll bar 1 point
WEVO roll bar mount
factory trailing arm bushing
Front
ERP Polybronze control arm bushing
factory control arm mounting bushing
ERP De-cambered ball joints
Sanders 22mm Torsion bars 1 point
ERP Bump steer kit
Turbo Tie Rods
ERP Triangulated strut brace 1 point
DOT50 tires 2 points
I appreciate any and all input. Please feel free to make any suggestions.
Rear
ERP Cambermax
WEVO roll bar mount
Front
ERP Bump steer kit
Turbo Tie Rods
RL Technical Advisor
Looks pretty close,..
Like Ed wrote, you DO need stiffer springs to go racing. The one very important thing I didn't see are shocks,...............those are truly "Mission Critical" for success.
Depending on your track preferences, I'd agree that slightly stiffer rear T-bars would be good. Of course, if you primarily AX in parking lots, not as critical.
I currently run an 83 SC with a 21F/30R T-bar set-up with custom valved stiff Bilsteins. Primarily I AX the car in San Diego. On the big tracks it has a slight oversteer "desire" that I find managable, however on the tight slow AX courses it turns in "briskly" and pivots very nice for pitch-and-catch throttle-steer applications. So it wil depend on what you do with it: big tracks vs. tight AX tracks. If you're going to primarily big-track it, definitely go to 30 or even 33mm rear T-bars.
My 2-cents. Good luck!!
