air box repaired ..
Team Owner
air box repaired ..
Can an airbox be repaired .. ? absolutely ? would I put a reapaired air box in my car ? nope ... but i will keep it as a spare.
What you need ..
assuming you have it all apart....
1. Brake cleaner
2. lots of clamps
3. marine silicon 5200 small will do preferably black ( i got the long cure time as I think you sacrifice holding power for time )
4. replacement screws
5. lots of time ( about a week )
The first thing i did was clean all the residue off both pieces with lots of brake cleaner. This is great stuff and really does a great job. On mine iIblew it completely apart ( long story ) so the anchors for the screws were toast. I just put them back for cosmetic reasons. about 3 out of the 12 bit in.
After cleaning it up I test fitted to make sure there were no holes or pieces missing. When I saw I had a perfect fit i applied my silicon to both surfaces. I really overdid it but who cares really as it was just a fun project .
I put the clamps and screws on , left it over a week and the thing is like SOLID.
a local Porsche buddy who came over didn't realize it was my airbox, thought it was my clamp storage device .... too funny......
i now have a workable spare. My replacement cost only 310.00 so it was worth throwing in a new one , but i imgaine going forward these are gonna be harder and harder to obtain .
Good luck
What you need ..
1. Brake cleaner
2. lots of clamps
Good luck
Team Owner
eBay alert number 321457666659267A has been posted...
Actually, you're lucky you had such a "clean" break, more often than not that isn't the case.
Team Owner
well you need lots and lots a gas for a clean break . not these ***** pops .. then you wait aproximately 5 minutes till it turns to vapour , you don't want a melted burning airbox, that is REAL hard to glue ... then after just the right amount of time turn it over ... it'l break pretty damn clean i tell ya !!!!
Legacy Flounder
Done Clive. This would be the kid that forgot to blue loctite his Audi TT motor mount bolts when he did the timing belt & water pump. Ask him how well his car plants the power down when the engine & trans are being held to the chassis by half a bolt, about to finish backing out...
Team Owner
What you need ..
1. Brake cleaner
2. lots of clamps
Good luck
What you need ..
1. Brake cleaner
2. lots of clamps
Good luck
Nice pics.
My air box may have been saved by a pop-off valve that a previous owner had installed. Had a backfire and found the pop-off valve itself had completely dislodged. I epoxied it back in and went merrily on my way.
Brett
Addicted Specialist
I've used epoxy on plastics before (that twin-tube syringe thingie), and that stuff dries hard as cement and has proven tough as nails. Your solution seems to work, though. And I personally don't see any reason why one "needs" to replace it if that one is solid. Nice job!
Edward
Edward
Team Owner
Hi Ed
I too am a huge fan of the two part epoxies. This stuff is the tiniest bit pliable which may work better in this application , plus I wanted an air tight seal and this seamed to fit the bill. However if I had not found this i was gonna use my 2 parter.
I am definitely keeping this one as a spare. If i had needed it i would have been a little neater with the glue too....hahaha
