AC switch
Recently i posted that the ac clutch wasnt engaging.
after doing some testing
the clutch is fine and it is not recieving 12v to accuate the clutch.
it is getting between 2 and 2.48 volts depending on where the ac switch is set at.
also if you check continunity between the wire and ground it has continunity so something is grounding somewhere between teh switch and the compressor.
I think i have narrowed it to the AC switch on the consul.
the replacement switch is different than the original.
the new one is flatter and wide with the wires on the back and the original is square and the wires hook up on the end
the new one wont fit in the consul.
what do i do now?
yes they have the same part #
what do i do now?
