Engine Stalling - Still
Background: '84 Carrera 3.2 stock. Car was running fine and then all of a sudden stalled. It fires back up but stalling within 20 seconds.
I replaced the DME relay with a known good one.
I replaced the fuel pump (old one had 138k miles on it anyways)
I replaced the fuel pump check valve.
I replaced the fuel filter.
I checked all the fuses, they are clean and in good order.
Battery is in good condition.
Car starts, but stalls 15 to 20 seconds afterward.![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
Help please.
Help please.
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
Maybe try ICV (Idle Control Valve)? Last year my '85 3.2 would stall on decel or when stopping at a light. I did a half as_ cleaning job re-installed the valve and everything was good. This year symptom re-appeared only worse.....I'd start up and the car would stall within 10-20 seconds. Ordered and installed a new ICV and everything is now fine. I've been driving all day with no issues. The part was $144.
Okay, I checked the ICV. The values are suppose to be 20 ohms from center terminal to each side terminal. On one side I am getting 20 ohms and on the other I'm getting 22 ohms. Is this too far out of tolerance to cause a problem?
Does the engine stall instantly like it is an ignition related fault or does it stumble and then die? I would check for vacuum leaks first. Get it to a shop to smoke test the intake. If there is a large enough vacuum leak, the engine could be running just rich enough on cold start to stay running, but once it warms up a bit and starts leaning out the mixture, it might be too lean to run. I would start here, and if there are no vacuum leaks, get back to us.
