Steve W. a question
Steve W. a question
Steve
A few months ago you stated my car would run better with the oxy sensor disconnected. The weather has changed for the better somewhat and the question I have is this. Will I have to adjust mixture, timing or anything else.
Thanks for the time.
Ernie 81 SC
Ernie 81 SC
Steve,
I have a Wideband O2 setup what AFR is = to 2.5% CO? I have wondered about this for some time now.
At idle fully warn I have simply set the AFR to 14.7 via the CO screw on the AFM.
Thanks.
Thanks.
I found this site that has a full table for converting CO Level to AFR
http://www.perfectpower.com/technical_info/afr.asp
