Help! Peter Z!!
Help! Peter Z!!
Engine lid won't open.
I have 84 Carrera and went to open the engine lid and it won't pop open. What do I do? Some time ago I did replace the cable, but the latch is original.
Thanks in advance.
Larry
Thanks in advance.
Larry
My tried-and-true single person method is to hit the upper left hand corner of the decklid with the bottom of your fist while pulling on the release handle. 9 times out of 10 this works. Otherwise, find a helper to give it a tug.
Gentlemen: Thanks.
I got my young son to pull the T-handle while I tugged on the lid - opened right up.
Maybe I should consider new latch assembly.
Thanks again.
Thanks again.
About the cable/latch. Make sure that you have the rubber spacer correctly installed under the T-handle, and that the adjustment at the latch is correct. When that's done, use a flashlight to watch the upper latch pin as you slowly lower the lid into place. The pin should be centered in the lower latch hole as the two mate (adjustment is done by loosening the two small bolts that secure the pin plate to the lid). Sometimes a pin length adjustment is also needed, but let's hear if everything else is OK first.
