Octane Requirements
#62
To further clarify (or confuse), and show that the possibility of your "200" number actually being correct, I have a factory Porsche publication that states the hp of '84/85 models as 204 DIN (in that reference 207 DIN didn't appear until '86), which converts to 200.9 SAE (round that down and you've got 200).
RoW 3.2 liter cars all developed 231 DIN (228 SAE) hp...
#63
RL Technical Advisor
#64
No need to start a new Ethanol thread...
https://rennlist.com/forums/showthre...ferrerid=27687
http://dorkiphus.net/porsche/showthr...hlight=ethanol
http://forums.pelicanparts.com/showt...hlight=ethanol
John
John
#67
"California was one of the first States to ban the gasoline additive methyl tertiary butyl ether (MTBE) after it was detected in ground water. Ethanol, a non-petroleum product usually made from corn, is being used in place of MTBE. Gasoline without MTBE is more expensive to produce and requires refineries to change the way they produce and distribute gasoline. Some supply dislocations and price surges occurred in the summer of 2003 as the State moved away from MTBE. Similar problems have also occurred in past fuel transitions."
#68
"Ethanol can't travel in pipelines along with gasoline, because it picks up excess water and impurities. As a result, ethanol needs to be transported by trucks, trains, or barges, which is more expensive and complicated than sending it down a pipeline. As refiners switched to ethanol this spring, the change in transport needs has likely contributed to the rise in gas prices. Some experts argue that the U. S. doesn't have adequate infrastructure for wide ethanol use."
"Also, ethanol contains less energy than gas. That means drivers have to make more frequent trips to the pump."
So, because it "picks up excess water and impurities," they won't send it through the pipelines but it is okay for our cars?
