Where to buy an SC headliner?
<a href="http://www.pelicanparts.com" target="_blank">www.pelicanparts.com</a>
<a href="http://www.performanceproducts.com" target="_blank">www.performanceproducts.com</a>
I know they have them. Good luck!
actually, the one in the car was sprayed black and I really hate the way it looks. The worst part is the overspray on the dome lights and the mirror on the sun visor.
A new liner is a bit more than I expected. I thought I saw one in a catalog for liek 54 bucks or so, but the liners on those sites are around 100.
I've seen them too that didn't turn out to good with a spray job.
It just takes a lot of prep and skill with spraying. I removed my dome lights. And the factory mirror is plastic and I got some solvent on it and it was history. So I went to local glass shop and had them cut me a mirror to put over the old one. I think I used that two way tape to hold it in place. Anyway that turned out to be an upgrade, looks great and it's a real glass mirror.
The reason I went this route was cost, and the job involved in replacing the headliner (ie taking the glass out)
If you do go this route it would be a good time to replace the windshield and rubber gaskets.
cheers <img src="graemlins/beerchug.gif" border="0" alt="[cheers]" />
Installing a headliner is a nightmare. You will typically pay $50 for the liner, and as much as $300 to have someone install it, which involves removing front and rear glass, as well as the door seals.
In The Book 101 Projects for your Porsche headliner replacement is project #68 and says, "it's one of the most difficult and complex projects in the book"
Sounds like a challenge
<img src="graemlins/drink.gif" border="0" alt="[cherrsagai]" />
Registered User
How do you go about spraying a headliner? my 82' has a cigarette smoke, stained, white one, which is also damaged beneath the roof aerial fitting, and after looking at the amount of work needed to replace it (ie; a lot)I read here that some have simply been sprayed. is this viable in black, or will it just look terrible?
