911 Forum 1964-1989
Starting problems
Old Apr 6, 2002 | 04:47 PM
simpson's Avatar
simpson
4th Gear
Post Starting problems
I have a 70 911T with CDS ignition.
The car will turn over and it is getting gas.
I don’t have any spark at the plugs,
The haynes manual talks about checking Ohm readings terminal 1,4,15 HT etc.
But it doesn’t explain which terminal is which.
I have a yellow on blue, blue and a brown at the coil.
The book also explains that because it is a CDS unit I shouldn’t see a spark at the points. ????
Shouldn’t there be voltage at the coil? And how much?
Mike
