3.2 hard oil line backdate for headers?
Hey Guys and Girls, fitting headers to my car but they’re fouling the hard oil line at the rear of the engine, any ideas what parts I need to backdate the oil lines? For example do I need SC lines?
I was thinking I could just get a flexible braided oil line made up but I have no idea the fitting sizes, any help would be much appreciated, cheers Spence
I know when i got my SSIs i had to get new oil lines (pre-74). I reckon the same would apply for you.
Pelican says: If you are installing SSI heat exchangers (or a pre-1974 style exhaust) onto a 1978-89 911SC or 911 Carrera, then you need to replace TWO oil lines. These replacement lines are original parts used on earlier 911 models, but since 1978-89 models adopted a "cross-over" style exhaust system, the lines are different.
The part numbers necessary are the following:
• 911-107-739-10-M20 - One (1) needed
And either:
• 911-107-729-10-M20 - For cars WITH a Front Oil Cooler
OR
• 911-107-728-00-M20 - For cars WITHOUT a Front Oil Cooler
http://www.pelicanparts.com/catalog/..._pg1.htm#item0
And either:
OR
