1982 European Targa ...What does that mean?
5th Gear
I will be looking at (to purchase) a 1982 Targa said to be a European model. Is this good bad or indifferent.
In my last posting I asked what the 0 - 60 stats of the early 80's Targa. I am a novice.I guess what I should have asked is what are the performance stats..
top speed, 0-30 30-60 times etc. 60 - 0 breaking time or is this something that is not available?
Or is it a fact that Porsche owners do not need anything to brag about...ownership being enough.
Rob
Rob
Euro models had higher horsepower (204 HP vs 180 for US models) due to higher compression and I believe lack of emissions equipment.
There is some good reading on 911SC's here:
<a href="http://tech.rennlist.com/911/911scfaq.html" target="_blank">http://tech.rennlist.com/911/911scfaq.html</a>
TOm
TOm
This is the performance section of a road test from the August 1980 issue of "Car and Driver"
![](https://members.rennlist.com/emcon5/SC_roadtest1.jpg)
![](https://members.rennlist.com/emcon5/SC_roadtest2.jpg)
The whole article, in a 1.7MB Adobe Acrobat file can be found <a href="http://members.rennlist.com/emcon5/cd-80sc.pdf" target="_blank">Here.</a>
I would like to give credit to the person who scanned it, but I found it on the web somewhere, and can't remember where.
Hope this helps,
Tom
Hope this helps,
Tom
21.1 gal fuel capacity and 13 quarts of oil? When the tank is dry I can only get 16 gallons in, and I have never used more that 10.5 quarts of oil when changing the oil with the Carerra oil cooler up front. Of course mine is a 78, so it may be different.
pbs911, there is a few quarts of oil left in the system when you drain the crankcase and oil tank. The 13 quarts specified is TOTAL capacity, again, you have a bit left in the system when you drain it out.
I find that I only have to put 10 quarts in my C2 once it's drained...but I don't have an engine oil cooler either, just the front mount...that's how they did the 3.6 cars.
Just thought I'd chime in with an "FYI".
