cab top/window seal replacement
I need to replace the outer seal between the window and my cab top. Pelican shows two seals, inner and outer. Do I need to do both? Is it possible/easy to just replace the outer seal. The fabric is torn and looks crappy, doesn't leak.
Or... is the process easier if I do both inner and outer???
thanks!
thanks!
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Nope, have not heard anything. Mine is an 86'. I did see a thread here a while back about this process but I can't find it in the archives. I think I did print it out and stick it in my garage files but I believe it was the process for doing both. I only need the outer seal. I'll just call Pelican and see if they know since they sell the parts.
good luck with your 97'
Hi, on the 86 model, which parts are you wanting to replace?
1986-1989 Cabriolet Top Side Seals
left inner- -911 561 187 00
right inner-911 561 187 00
left outer- 911 561 189 66 8VB
right outer-911 561 190 66 8VB
Cabriolet "B" Pillar Seals
1986-ON
left-- 911 561 681 01 8VB
right-911 561 682 01 8VB
I could not be able to tell you what the easiest way or best way to go would be. When I replaced my 1984 top, I used all new hardware and seals. I am not sure about the later tops. Hope some of this will help. Tony.
1986-ON
The info I'm looking for is...
Can I just replace the outer seal, it has fabric on it. The inner seal is fine. I wanted to know if when removing the outer seal the inner seal will get damaged and if you need to replace both at once?
thanks to anyone that can advise!
