911 Forum 1964-1989
occasional smell of rotten eggs
Old 01-19-2008, 10:06 PM
joey c
joey c's Avatar
Default occasional smell of rotten eggs
its happened 2 times in the last few months..i recall reading something about this..i thought nothing about the 1st time but it happened again the other day...any thoughts..thanks,joey
Old 01-19-2008, 10:20 PM
porsche930dude
porsche930dude's Avatar
Old age will do that I get it whenever my brother is around
Old 01-19-2008, 10:35 PM
WolfeMacleod
WolfeMacleod's Avatar
That will be your battery overcharging.
Fix the problem, before the battery explodes and sends acid shooting all over.
Happened to me once in an old Celica. Wasn't pretty.
Old 01-19-2008, 11:31 PM
3.2SLANTNOSE
3.2SLANTNOSE's Avatar
It can also come from the exhaust, when a cat. converter is contaminated, or fuel mix is way off. You did not mention the car, or where you are located, so I don't know if yours even has one. When it does that, it is discharging hydrogen sulfide along with the other exhaust fumes. It can also be charging related to your battery, maybe you have a voltage regulator overcharging you battery, as mentioned already. Good luck!! Tony.
Old 01-19-2008, 11:55 PM
Oshin11
Oshin11's Avatar
I am now an expert at this, happened to my car on a 2000 mile endurance drive. Ill PM you with my number and you can call me on Sunday, took me a long time to diagnose it but you can benefit from my insanity and experience We'll figure it out over the phone. Check your inbox.
Old 01-20-2008, 11:39 AM
theiceman
Team Owner
theiceman's Avatar
Received 1,119 Likes on 801 Posts
...hook up a volt meter to your car ( any 12v line will do ) see where your 12 v is sitting. I would say you are spiking. This is such a common problem with the older 911s that I have a permanently mounted voltmeter. A damaged alternator/ regulator can :
1. boil your battery destroying it ( the sulpher smell )
2. spill out into the battery box , destroying it
3. Damage the electronics in your car ( beware if you have a DME car. )
Although it could be the exhaust I would assume electrical and work from there ( assume worse case as it will help you in the long run . )
Old 01-20-2008, 11:46 AM
Peter Zimmermann
Peter Zimmermann's Avatar
joey: "ice" is correct, your symptom is a classic alternator/regulator problem, especially if you have a car that uses an internal regulator ('82/83 SC & '84> C3.2). Please heed his cautions...
Old 01-20-2008, 03:46 PM
joey c
joey c's Avatar
my car is an 87..the alternator is 20k old...i do have a steve wong chip...the smell is pretty rotten,then it goes away..its not a regular thing...checked the battery,all looked fine..thanks,j
Old 01-20-2008, 03:47 PM
joey c
joey c's Avatar
when checking the voltage,car on or off..sorry iam a pianoplayer and know nothing about this ****..thanks again,j
Old 01-20-2008, 04:05 PM
Chuck Jones
Chuck Jones's Avatar
It's great to see a piano player with a sense of humor. Car needs to be running.....you have to measure the output of the alternator/regulator as it is putting voltage INTO your battery. Your battery can only take so much, then it's the job of the regulator to cut off the flow of electricity. It if doesn't, then the battery is overcharged and boils....that's when you get the smell of sulphur dioxide....rotten eggs.
Hopefully it's just the regulator...cheaper than an alternator.
Old 01-20-2008, 04:27 PM
joey c
joey c's Avatar
car running...its was at about 14..
could it be bad gas
bad cat
maybe a farted and did'nt realize it..thanks j
Old 01-20-2008, 05:41 PM
porsche930dude
like you said it only happens sometimes so the regulator only sticks sometimes. Still needs to be replaced or taken apart and cleaned/ lubed
Old 01-20-2008, 06:21 PM
JV911
JV911's Avatar
+1
i went through this in november.
the first hint of a problem was a bouncing tacho. my initial though was "voltage regulator". but the prob was intermittent so when i tested the voltage it measured correctly.
then on a spirited drive one day i got the rotten egg smell (and i hadn't had kidney beans the night before!)
so the voltage reg was replaced as too was the battery
Old 01-21-2008, 10:38 AM
kick7ca
kick7ca's Avatar
Is this a private problem? Why not share an informative reply on the thread so that others may benefit?
Old 01-21-2008, 12:55 PM
3.2SLANTNOSE
kick7ca, very true!
Quick Reply: occasional smell of rotten eggs
