Did 911vet go into her garage for a project and never come out ...
#31
Did you manage to work around the cat on the bottom end ? I have heard that can be tricky , also did it take a bit of practice to get the technique down or were you able to get a good feel for how tight it should be right away ? ...
okay guys read into it what you want but these are serious questions !!
OK, if you are serious, and I really can't tell anymore!!... it was pretty easy working around the cat (I am going to resist the temptation to use the other obvious term that comes to mind here). I did have to cut a screwdriver so it was very stubby (oh, no, another inuendo!). I didn't find working on the cat side was significantly harder than doing the other side.
I really struggled with getting the right feel for how tight the gauge should be. This was the first vavle adjustment I've ever done. I ended up going through it 3 times before I was somewhat satisfied. I could have tinkered with it endlessly trying to get it just right. But the fact that it's damn near impossible to set the gap and then tighten the bolt without changing the gap... well, I'd never be satisfied I had them "just right."
The biggest issue I had was the feeler gauge would become contorted after a while and it then rendered an inconsistent feel. Move it to the left, it felt to too tight. To the right, too loose.
So my best advice --- now that I am a professional --- is buy a lot of extra blades. Change them as soon as they get jabborwacky so you have a consistent feel.
There is a lot of subjectivity to this process. It should be a straightforward "the gauge goes in or it doesn't" but that is far from the truth. At least it was for me. Next time, they will be tighter.
The whole job took me about 13 to 15 hours. That's from the time I put the jack under the car until I had it all bolted back together (oil change, oil filter, new spark plugs, new distributor cap and rotor, valve covers back on, new oil in).
I spent about 1 hour on the first valve! Last vavle took about 15 minutes. There was quite a learning curve.
#32
Shannon
Yeah i did this one with little problem . The inner ones are easy as you take each wheel off and reach in with a few long extentions siting outside. I did what you did. and use a allen key bit on an extention the outer ones were a bit tricker as you have to climb under , do a couple and then turn the wheel. I found my parking brake gripped it well enough. I did oit with the whole back end in the air on axle stands. On the 964 there is no parking brake on the front so it is a PITA.
I'll leave the wheel hub on to break the bolts free. So if my brake isn't enough to hold, I've got an alternative. Never thought of that... no wonder my buddy had such a fit with his C4
#33
Tie wraps?! The other Porsche pilots would laugh at me.
He's an idiot. But, I love him anyway.
#35
On my early car (1969) letting the wheels/tires hang (while jacked up) put too much angle on the rear joints to allow access to all the bolts (boot was in the way at the top). However, by turning the wheel/tire by hand and slowly removing the bolts part-way ...I finally got them out.
Installed in the reverse manner.
I used large, black/plastic zip ties to seal the boots. Time will tell on endurance of these.
#36
Tie straps....Who's gonna crawl under there and look?
I will let the "boyfriend is an idiot" comment lay, but he is lucky.
#37
I have done lots of CV joints on different cars. My SC has fuly rebuildable inners and outers, yours may have sealed inners but I am not sure.
The parking brake should definitely hold. If it doesn't theres your next project. A few other points from my many CV joint rebuilds.
1. inspect your bolts carefully. They may be " triple square" bolts, this driver is readily available at most retailers and ataches to your extention. If it is a allen key or " hex" even better. My 944 was tripple square , my SC was allen key. Getting the wrong ones could cause it to strip. Also clean the bolt holes and make sure you have your driver well seated.
2. You should replace the bolts on this project, they are cheap insurance.
3. You should have schnorr washers on the bolts . if not add some when reasmbling. These are serated bevelled washers that use friction to hold ( serated ) as well as spring tension. ( More on this in a minute )
4. When cleaning and inspecting yor CV joints you should NOT use solvents , just soap and water. If you do use solvents make sure you wash your CV joints throughly with soap and water afterwards. trace solvents can brake down your CV grease very quickly and destroy your joints. ( i put mine in the dishwasher while my wife went out shopping. )
5. inspect the components carefully. chck for breaks in the casting like the pic I posted. Personally i thought 90.00 per joint was cheap so just replaced them all.
6. The SC requires paper type gaskets on reassembly, not sure what you are driving or if it requires gaskets. This is one of the reasons you want to retorque and use the the serated washers. After you tourque, down the road the gasket compresses and that in effect loosesns the bolt. Also getting grease in the bolt holes cause them to back out. if they get loose enough they can get fall right out or shear off.
7. One method of assembling is to assemble with the old bolts. and when you are done take the bolts out one at a time, clean the bolt hole with brake cleaner and a test tube cleaner, and reinstall with a fresh bolt and schnorr washer. Torque to spec , move to the next bolt hole and repeat. Takes a while but is a sound method.
8. No matter the method reinspect and retorque after 1,000 , then 3000 miles ( next oil change. )
I hope this helps, you can repost or PM with questions.
WOW ... all that with no inuendo ... I like to have fun but working on your car is serious business.
BTW having the axle hanging actually helped in my case as sitting by the car made it easy to get in the top of the cv joints to get the bolts.
As far as the valve adjustment goes. I do have 10 spare blades. and the special J tool . I will probably do it over the next few weeks as my car is in the garage for the winter. my plan was to just tighten it down with the feeler in there , then wiggle it out .. if it wiggles out and I can wiggle it back in , it should be fine right ? .. what do you think having done it ?
#38
I looked at the Performance pliers and like Douglas mentioned, they look pretty week for the job they have to do. Mine are Oeticker brand and heavy steel and aren't going to bend in use. I'll box em up if you decide you want to borrow them.
Yeah, my boyfriend is a lucky guy --- he has an 89 964 C4.
#39
Lucke27, I understand you.
You'd rather see avatars of people you've never met than talk to your family.
You think chicks with grease under their fingernails are sexier than ones with nail polish
You believe an in depth discussion of valve adjustment is more intellectually stimulating than a presidential debate.
You'd rather spend an evening tweeking a torsion bar than at the bar.
You dream of buying a 930 steering wheel.
And, you know the best thing about owning a 911 is that there are other people who are just as stupid about them as you are
#40
If I have these washers, can I reuse them? Or do I need to replace them along with new bolts?
Geez, I hear these comments all the time. I sure am glad I don't have a wife
No wonder I'm not a wife... I would never be able to live up to the reputation. I'd be the one putting them in the dishwasher myself. Oh - and I drive with the top down. Even when it messes up my hair. That's what pony tails and baseball caps are for! And just one more rant.... on the last local PCA drive, I was the ONLY female driver and I was the ONLY one with the top down!! The other drivers were wusses. You know the type... Boxster drivers mostly OK, I feel better. Back to the important stuff:
Gee... I got off on a tangent again, didn't I?
It's my inside boot that is torn. So I think I could do this project by just dropping it. However, I decided I would not do anything so rational. Instead, I'm removing the whole drive axle so I can replace the outer boot at the same time just as a preventive measure. I'm an idiot, aren't I?
#41
If you intentionally leave a little slack and let the nut draw it down, you're going to end up with inconsistent results (in my humble opinion). Though that is some people's prefered approach.
I think you have to be able to actually move the feeler gauge a little before you pull it out. If it can't move, you are too tight and you won't get it back in.
The advice I got was "if gravity were allowed to act on it, the blade should NOT fall out. It should just be held in place." I found that useful.
By the third time through, I figured out I needed to feel that the top of the blade was in contact with the rocker foot, and the bottom was in contact with the valve tip at the same time. As in, "It should drag, not slide." Sound obvious... but when I kept that in mind, it helped.
I had them too loose the first time through. Because I was going on the advice there should be a "magnetic feel." And I'll say that I did detect that, but I needed to think a stronger magnet!
When I was done, I could get the feeler back in but I had to work at it. Some went easier than others. I stopped fretting over that, since I realized that no matter how "perfect" I had the adjustment before I tightened the nut, it was going to change. So I lived with a little inconsistency. Trying to tweek each one could drive you slowly insane after a while.
Lastly... I suggest that before you begin your adjustment, note the position of the adjustment screw (i.e. the top of the slot is at it's at 10 o'clock, 12 o'oclock, 2 o'clock etc). This allows you to have some confidence that you aren't somewhere out in left field when you're done. And if you end up in just about the same spot you started... you should feel pretty good you haven't really botched it. That helped me be a bit more confident I was opening up a valve to some crazy setting.
In the end, I had an engine that sounded pretty good to my untrained ears. I can hear some ticking. But, it's a Porsche 911. If it didn't have some ticking, I'd worry.
Let's put it this way... I won't be embarrassed at the next PCA drive when someone listens to my engine and I tell them I adjusted the valves myself. It sounds good enough for that
SO.... if I, with ZERO internal engine experience, can do this by myself in a friend's garage on a couple of lazy winter afternoons... you can do it.
Have fun.
#42
They are hex nuts. I have a socket with hex (allen) insert. If I can cut the bad boot off, I can get it in there. I will be careful to clean the nut first so I can get the allen properly seated.
If in doubt tap the end of your extention with a hammer to get a good seat.
If they are still bevelled you can use them , but they are fairly cheap. Mine nevr had any so I added them. They don't "stretch" like the bolts do though.
Great tip. I would have never thought of that. Probably would have soaked them in gasoline. Dawn soap it is.
I used some old rags to get the thick off, then soap and water in a bucket. The absolute best cleaner I have found in Tide HD for front loading washers. It is all I use for cleaning my hands too.
I wouldn't blame her for giving me grief for putting car parts in the dishwasher, but she was pretty understanding with my rotors in the oven... 20 mins at 350 .
I considered buying a whole new drive axle. But my CV joint feels ok when I try to find slop by manipulating it by hand. I can get medial/lateral movement only, which I assume is normal.
When you get them cleaned up , you will be able to do a close inspection. I don't belive in the "play" test.. mine felt fine too... and look how damaged they were.
Thanks, you may have just saved my life.
not really . Just maybe an agrivating break down.
I like to have fun with y'all. But I am a serious Porsche owner. I find working on my 911 to be a Zen experience. I'm in the moment. Thinking of nothing else. Just me and the car and the tools. It really is calming. Well, until I can't break a bolt loose then I go from Zen to Rambo and really want to hurt something. I usually end up hurting my knuckles.
No not really . We are much alike , that is why I have done so much with my car , and when it comes to help people working on it, just the facts ma'am just the facts ..
besides, it is likely the outside one will start clicking as soon as your done if you don't do it.
When I did it I used lots of latex gloves, newspaper , and wore clothes I could throw away when done.
I Still have no idea what you are driving ? If it is a car with the inner cv joint sealed, you have to remove the outer boot and CV joint to replace the inner boot anyway.
You may need a circlip remover, then it will slip off. A few blows with a dead hammer may be needed. look carfully how it is configured. I may have a pic of mine .. but what a mess.. Yuck ...
#43
Here is a pic of mine when I got it out..
Oh BTW I can't remember if I told you . I had NO symptoms. but my CV joint was busted up all the same.
#44
The outer may be the sealed on looking at the PET but I can't get a good look. Pete Z or Steve may know. IF that is the case you may have to remove the axle disconnect the inner and drive the axle out through the hub. that axle nut will be seriously tight ..
#45
I bought 2 boot kits from Pelican so I can do both the inner and outer --- like you say, the outer would go bad if I didn't.
I'm not sure what tools I will need - I don't have a circlip remover. I'll get one. amr89C4 is going to loan me his tool for installing the new clamps.
87 Carrera Cabriolet w/ limited slip diff.
