Easy Valve Adjustment
Here's the easy way to do valve adjust as told to me by Bruce Abbot;
The thread pitch is 1mm. Spray the adjuster with brake clean to remove the oil. Turn the adjuster to the valve, back off 1/4 turn and split the 1/4 while tightening. This would give you .12mm in a perfect world & the engine will run well & quiet. With the oil running on the parts you'll get .1mm with a dial guage.
It's quick & has worked fine for me..........no 8 hour valve adjust!!!!!
Steve
83SC
Steve
83SC
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
All the methods mentioned in this thread work well. The one that Steve mentioned or was given advise on works great too, however... it may be better suited to those a little more familiar with valve adjustments, or better yet, peforming valve adjustments on these engines.
The gentleman who provided Steve with this method is a proficient and longtime engine builder/tuner.. and I'm sure he could probably perform the whole operation blind folded and by feel only. Well, it's kinda like your doing that anyway huh?
![Wink](https://rennlist.com/forums/images/icons/icon12.gif)
![manual](https://rennlist.com/forums/graemlins/rtfm.gif)
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
I'm not trying to sound like a wise guy, but if one is going to try something as technical as adjusting the valves on a engine that is going to cost THOUSANDS if done incorrectly, please spend the $$$ and get yourself a Bentley's Manual or 101 Projects for your Porsche. That way you will be better equipped to understand .
The original post (& clarification) describes a very good method for valve adjustment. It also happens to be one that I tried, but initially ran into the "visibility" problem - seeing relatively small adjustment screw rotation angles (1/4 & 1/8 turn) on some of the cylinders can be very difficult.
It took me awhile, but now I'm using a light & inspection mirror, along with a magnetic base for mounting the light & mirror at the correct angles, while doing the valve adjustment.
To be honest , I messed up several times in not remembering that everything in the mirror is reversed!
Overall, however, this seems to be working out well. Thanks Bruce Abbot, Steve & Brett.
Excellent, you will find the Bentleys much more detailed than the 101 projects.
