Scanner for 1987-911
Hi Gang,
I was wondering if there is such a scanner tool for diagnosing an 1987 911 carreera. If yes, where can I buy one of those and roughly how much. My understanding is that any OBD1 or 2 scanners are for newer cars only.
thanks for the info. much appreciated.
youngatheart.
youngatheart.
Not really. 964s are the earliest 911s that work with the Bosch Hammer scan tool. The early L-jet DMEs on the Carrera 3.2s are simple, they don't store fault codes. Apparently there is a special breakout box that Bosch made to make testing all the DME pinouts easier, but my shop doesn't even have that. If you have access to the factory manual and a good meter and electrical knowledge, you should be able to figure out most issues. If not, find a good Porsche shop!
Actually,you will want to use a digital multimeter. An analog meter doesn't have high enough internal resistance, which means that if you are testing a circuit, the analog meter will draw too much current and possibly skew the reading. Also, if you use an analog meter to test a computer circuit, you can possibly damage it by allowing too much by to flow through the circuit. A digital multimeter has much higher impedance, in the millions of ohms. You can get a halfway decent DMM at Sears or similar places, but Flukes are the best if you can swing it.
The analogs are the way to go when measuring a variable resistance, as measured on a typical potentiometer,etc....as their's no autoranging "blips" in metering. Otherwise, digital (yeah)....a good Fluke.
Best,
Best,
I was just joking about the analogue one because I had to use my dad's ancient one the other day because the cheap digital one died on me. I was more or less just looking for continuity or 12V. Nothing elaborate. That multimeter must be older that I am.
Team Owner
I actually I got the Jooke Matt .. i was going to ask how your 1960's Rusian - Chineze meter was before I read the other posts.
A few of the posts above are correct. I use a Fluke 87 for most measurements. but I also have a 100 Mhz hameg scope for fast rise times and pulse signals. The problem with most meters is the sample rate and if the voltage changes rapidly you won't get a reading. i also have an old analog like mats i use when I just want to see a " deflection" on the meter.
