Starter Motor
Oddly enough, the Bentley manual doesn't seem to give these figures. I did find, however, that on an 88 Carrera, the battery load test is to pull 200 amps for 15 seconds and have the battery show 9.5V at 60F. So this might have some correlation to a healthy starter load.
1 Post
starter solenoid around 10 amps
starter draw around 100 amps in good condition with good wiring. Engine timing, engine compression, etc can affect current draw.
the common 911 starter cranking problem is often not the starter. When this issue arises I would get under there and directly jump the solenoid from the starter battery terminal. That will help diagnosis.
