1986 911 Brake Upgrade
4th Gear
I'm looking to upgrade my brakes on my 1986 Carrera. Has anyone ever put a set of 944 Turbo brakes on a 911? If so, is it difficult. Any other suggestions would be appreciated.
Thanks,
Chris
Thanks,
Chris
Since the search function seems to have disappeared, I'll suggest that you may want to read this page
<a href="http://home.nycap.rr.com/wmv/generalbrmd.htm" target="_blank">911 brake Mods</a>
Bottom line is bigger rotors are needed along w/ the calipers
There are several ways to do this. Here is one way
<a href="http://home.nycap.rr.com/wmv/964to911.htm" target="_blank">964/944t brakes on a 911</a>
here is another
<a href="http://www.vehiclecraft.com/Brakes/VCI911_2_964.htm" target="_blank">VCI 964 brakes for a 911</a>
Please do not fall into the trap of trying to elongate the 94mm 964/944T caliper mounts to fit on 3.5" ears. I know it's tantalizing but it's a really really bad idea!!
<img border="0" alt="[cheers]" title="" src="graemlins/beerchug.gif" />
here is another
RL Technical Advisor
Hi Chris:
I'd just chime in here and offer one more opinion,.....
You cannot go wrong with 930 brakes on a car like yours. These have more than enough heat dissipation capacity, good brake biasing, and will fit inside any 15" or 16" wheel you use.
IMHO, anything less is insufficent if you plan on participating in track events.
