Driveway Help
I sold my 84 Targa before we bought our new house. Unfortunately, the new house has a very steep driveway leading to the garage. It doesn't just go directly to the full-incline, but tapers for the first several feet.
My challenge is I know I want another 911 again someday (perhaps sooner rather than later) and am keeping my eyes out for one that suits me, but before I get too far along, or stumble into a good deal on a solid car, I need to see if I can even get one up the hill and into the garage.
A friend of mine does have a 912, but I don't know anyone with a 911 locally. Any other suggestions for checking this out? I suspect the geometry I learned back in school could be used, but I'd need some help getting the measurements from the front and rear of someone else's 911.
Alternatively, anyone else on here close to Little Rock, AR and wouldn't mind swinging my the house someday so we could check it out?
Pretty simple I would think. Measure the from the lip of the front spoiler to the ground. Then measure the distance from the front of the spoiler to the front tires. Then measure vertically and horizontally on the driveway the same way.
I may try to run by my old mechanics tomorrow and see if he has any 911s in I can measure. If anyone has a few spare minutes on a stock height car, it would be great if they could take those measurements for me.
I track my car so it is quite a bit lower than stock and I have an aftermarket front valance that is really low.I have to be very careful. Even speed bumps can rub me the wrong way.
Is the entry to your new driveway 90 deg. to the street or is it angled a bit? Coming in at an angle sometimes alleviate the problem.
once you had some measurements you could make a cardboad template of the car
It would have to be a pretty big arc to high center the car you would have more of a problem with the front valance hitting on an up slope. I thnk my car is about 6 inches to the floorboard between the wheels
The driveway is pretty wide, so I can get an angle on it and would almost certainly have to do that. It starts out at the same incline as the road itself, then over the course of several feet angles up to what is ultimately a really steep incline... steep enough that kids on Halloween look at it and often pass on by instead of walking up.
I'm not really concerned w/ high-centering as it levels out more gradually, but more scraping the front and dragging the rear going in and out down at the street.
Douglas, are you stock height or have you lowered at all?
Now all you have to do is make a corrugated cut out of a 911 front end and stick it on your WJ bumper and drive in the driveway. You may want to pre-warn (no not a Warn winch) your neighbors that you have not lost your mind, but that you are doing top secret research... the wheel base is perfect on that thing to duplicate both the front and the rear end. You may have issues out back too.
Get the car you want and move
? Mine's euro height, and I hit the front tow hooks a couple of times (but not on my driveway) before I figured it out. I now use a "slow, angled" approach on anything that's close, and haven't had an issue since.
Keith
'88 CE coupe
? Mine's euro height, and I hit the front tow hooks a couple of times (but not on my driveway) before I figured it out. I now use a "slow, angled" approach on anything that's close, and haven't had an issue since. Keith
'88 CE coupe
I couldn't get any of our cars in or out of the driveway in our new house, so the first thing we did was have 30 feet all torn out, 2 ft. of elevation lowered and the slope regraded, then 2 ft retaining walls, and pour a new drive. One $5k mod that fixed 4 cars at once!
