What is an ///M5
http://www.elephantracing.com/suspen...iondiagram.htm
I added it all up. About $5200.
I looked at some of my old receipts and they total around $2500 in suspension mods on my 79SC for the parts I upgraded. I didn't do all the upgrades shown in the diagram.
I only ended up 1) replacing my stock shocks with 4 Bilstein Sports 2) Replaced the stock torsion bars with 21mm front/27mm rear hollow Weltmeisters 3) Installed Neatrix bushings for the stock units that were flattened due to age and 4) lowered the car to around 24"/24.5" and got an alignment. I also changed the tires to Bridgestones but I didn't include that in the pricing.
These changes alone improved my track time on a 2 mile circuit by about 8 seconds. The car is much more planted and predictable. My SC came with Woodhead shocks as the OEM and the Bilsteins really brought the car back to life.
Here's a good technical article that I used in selecting how much additional stiffness I wanted via the upgraded torsion bars. It also shows what the stock torsion bar diameters are for SC's and Carrera's.
http://www.pelicanparts.com/techarti...rsion_bars.htm
I did all the work myself except the lowering and alignment. I must say that replacing the rear spring plate bushing is the most difficult project I've done to date on my SC. You literally have to cut or burn the bushing off. I ended up using a torch and it comes off in a hundred pieces although I've heard some that have been able to get it off in one piece. In hindsight, that's one job I'd pay to have done.
Bottom line is if you still have stock suspension parts on a SC or Carrera, these changes will really improve the handling of your car. IMO.
One last thought, I spread out the upgrades over a 2 year period to spread the cost and so I could evaluate each change rather than just throwing parts at it. First I did my shocks, then drove the car at a track event to see the effect and determine if I needed to change my torsion bar ratios. It meant I needed two alignments but I had a better idea of what ratios to use.
You may be able to find the 26mm t-bars relatively cheap as they were factory 930 bar size.. On a cab, I like them with a 21 mm front bar, and the Bilstein HD in front along with strut bar... just in an attempt to cut down on cowl shake. I'd go through and replace the rubber bushings as needed also... with new rubber ones, again.. just because its an open car. Just a thought!
Do it soon.. can't let those miata things get that close!
P-
P-
Is there a reason to go with Bilstein HD rather than Sport? And are you suggesting Sports in the rear and HD in the front?
I will definitely be adding a front strut bar. And I figured new bushings and ball joints were probably needed.
I'm talking to the guys at the body shop about welding together a bar to stiffen the chasis in the passenger area of the cockpit. My roll bar makes a significant improvement in chasis stiffness and handling. But I've been advised against using it with stock seats (due to possible spinal injury in a rear-end collision). But I was thinking (dangerous) that maybe my buddies at the shop could weld some kind of bar that runs across the floor of the passenger compartment.... what do you think? Anyone ever done such a thing?
I would rather spend money on suspension upgrades than the $2000 it would cost to get Recaro seats, harnesses, seat braces, etc just to use the roll bar. Then again, that would allow me to use it at DE school.
What to do, what to do.
http://www.rallylights.com/other/stuning.htm
I will turn to you guys for advice on good set ups. Thanks.
http://www.youtube.com/watch?v=Z3zOKHNkv-4
Now this was just down right hilarious...
Thanks for lightening up this post...
Jitters
By the way, the Audi never even enters into conversation when I am talking about my sports cars.
Was this what you saw? : http://www.bmwusa.com/vehicles/m/m5sedan/default
.Slinging 2700 lbs around at speed is fun. Slinging 4500 lbs around at speed is, to me, kinda scary and unnatural.
http://www.youtube.com/watch?v=dy5Twk4Wd7o
http://www.youtube.com/watch?v=_zYWOqm_Zkc
