Capacities
Capacities
Hi Guys, my '78 didn't come with a manual and I am just putting it away and need to know what the fuel tank capacity is so I can add the correct amount of fuel stabilizer.
Also, am I correct in assuming that the white spout next to the fuel filler cap is for windshield washer fluid. Mine is either empty or my pump is broken. Should I hear a noise when I try to use it even if it is empty. If it is empty, I am thinking I should leave it empty so that I can replace the pump without making a mess. I have not looked yet to see if the tank is visible in the front trunk to judge how much, if any, is in there.
Justin
I have a 78SC manual i transposed into word ( basically just scanned it in. ) come out one Saturday and I will put it on CD for you ( not this Saturday though as I am out of town ) . I think I have actually gotten 80 litres into the tank. the widshield washer fluid is a small white pump in the front, mine was seized too so I took it apart and cleaned it , even to buy it is cheap. Do you have headlight washers? That one is more challenging.
MY 1987 is 85 litres - 22.5 US gallons.
Your W/W pump might work, but the in-line check valves might be clogged - this is very common. Inside the trunk below each wiper you will find the lines. Each has a 90 degree valve. Disconnect on the pump side & try the W/W. If you get fluid, then it is the valve. If not, investigate the pump & wiring.
Ian
Ian
Justin
Just to make sure I am clear, under my gas door, I have a white plastic spout to the left of the gas cap. Is that where I add washer fluid?
