headlight switch resto?
My headlight switch is showing a little bit of wear such that you are seeing a little white in spots that should notbe white...
I hate to replace the whole switch just to make it look nicer. Has anyone had any luck with a paint or ??? to touch up the switch without it being too obvious?
Is this what you are looking for?
http://www.pelicanparts.com/catalog/...11M_INTdsh_pg6.
$4.00 plus S/H
$4.00 plus S/H
Thank you Gerry... that is it, only not. I think my emblem looks slightly different. I need to check when I get home. I guess if it is not exact, it is the next best thing. Thanks again for the tip!
